Hydroboost Power Brake Booster
I am going to be grafting a Hydroboost Power Brake Booster into my '69 this weekend due to insufficient vacuum for the vacuum booster. I wanted to get a reman unit but no one has one in stock with none to be seen for an unknown time. Thus I will use the unit from the '78 Eldorado I bought for this very reason. I will update this thread once I complete the job.
Re: Hydroboost Power Brake Booster
Installation was fairly smooth but I did need to modify the inner fenderwell, re-use the stock power steering pump as the Eldo pump did not fit the bracket, and I had to use the Eldo Master Cylinder which required a slight re-plumping of the brake lines as the positions of the front and rear reservior are swapped.
Braking performance is simply stunning. Very little pedal travel - 2 to 3 inches - and rock solid brake feel after that. I suspect I could lock the wheels in a heartbeat, and braking response is instantaneous.
I based my upgrade on stock Eldorado parts. There are, however, many aftermarket kits that will work; virtually any GM unit should fit fine.
I highly recommend this upgrade to anyone contemplating an aggressive cam or that just wants the best brakes possible.
One more modification that will be needed for the Hydroboost unit I chose - it has an accumulator which provides three stops with the engine off. The accumulator comes very close to the exhaust pipe coming out of the manifold.
My solution was to whack the pipe right on the location in the bend where the interference was. I flattened it a bit and then wrapped it in DEI exhaust insulation wrap and it seems to be working great now.
There is a version of the Hydroboost that Twilight found for a mid 80s Regal and probably a few other cars. This one seems to lack the accumulator and therefore will fit with no interference issues. Not sure what it does with respect to braking with the engine off, but it looks like it fits much better.
Either way I highly recommend the conversion, esp. if you have an aggressive cam and poor vacuum.
Return to “Suspension, Brakes & Steering”
Users browsing this forum: No registered users and 61 guests
