U4GM Presents: The Boulder Build for Diablo Season 2025
Use this forum for test posts and to see how this forum works.
jeanbb
Postby jeanbb » Sun Feb 16, 2025 11:38 pm
If you’re a Diablo player looking for something fresh and powerful this season, the Boulder build is one you need to try. With the help of U4GM, you can equip yourself with everything you need to maximize your potential in Diablo 4. Diablo 4 Boosting buy offers fast delivery, secure transactions, and a wide selection of items to help you boost your gear and stats efficiently.
Key Components of the Build
1. Hurricane and Boulder Mechanics
To get started, cast Hurricane to set the boulders spinning. Keep casting the Boulder skill to build up to 10 stacks. This stack triggers Dolman Stone’s damage boost. The goal is to keep your stacks active for as long as possible by managing Hurricane’s cooldown efficiently, allowing you to maintain a steady stream of damage.
2. Spirit Management
Spirit management is crucial for this build. It can sometimes get low, but don’t worry, Tibbal’s Will comes to the rescue. By using your Ultimate or Bullwork abilities, you can instantly replenish your spirit, ensuring you stay in the fight. Tibbal's Will is particularly useful for managing spirit without losing damage.
3. Shape-Shifting and Hunter Zenith
This build also takes advantage of shape-shifting mechanics, where you swap between Claw and Boulder skills. This is key for activating Quickshift bonuses and Hunter Zenith, which grants an Overpower every 30 seconds and reduces the cooldown for abilities, boosting overall build efficiency.
Ready to give the Boulder build a try? Head over to Diablo 4 gold and get everything you need to make your Diablo 4 adventure even better.
Return to “Test Forum”
