425 toronado horse-power
followme21
Years Owned: 66 toronado
Postby followme21 » Wed Sep 29, 2010 4:51 pm
So what is the difference between a 1966 425 in a Toronado rated at 385 HP, and I regular 1966 425 rated at 375 HP? The bore and stroke are the same and the compression ratio is the same, according to my chiltons book. Where does the other 10 HP come from? Thanks
Graniteman
TOA Membership Number: 70
Years Owned: Owned a '69 back in about '77, this cat was a legend in the Nebraska panhandle, it was very fast even for it's size. It would absoloutly fog the front tires from a standing start; I don't mean spin them, I mean just boil 'em from a standing start for at least 100' (measured)! I know what you're thinking, they weren't old rag tires they were modern Yokohoma radials. I'm sure this car would have ran 150mph too because many times I had the cruise set on 135 with 1/2 the gas pedal left. BTW this was in the middle of nowhere Wyoming.
I also may be building some new wheels with the correct offset, etc.
Re: 425 toronado horse-power
Postby Graniteman » Sat Oct 02, 2010 1:01 pm
CAM
TOA # 70
