Fuel Tank Replacement
Willysnut1959
Postby Willysnut1959 » Thu Feb 04, 2021 4:52 pm
Stilling having fuel delivery problems on my '66 after rebuilding carb, installing new in-line fuel filter, hoses and hard lines (all the way back to the tank, and fuel pump. Car ran out of fresh, no-ethanol, high octane fuel on my last test drive with 15 gallons in the tank. I pulled the tank yesterday and found outside top of tank to have caked dirt and rust. The exterior bottom looks to be in excellent shape. Due to it raining all day, I have not yet opened it and looked inside. When I dumped the last bit of gas out of the fill tube, significant particles of rust came with it.
Contemplating my next move. I have two other used Toronado tanks I could install or 2) sandblast the original one and have it boiled out and lined, or purchase new tank. I would prefer to use a new fuel tank, float and sender unit, but can not find a replacement tank for this car.
Original tank looks similar in size to the one I replaced in my '72 Cutlass. Differences appear to be the filler neck, location of fuel hoses connection points, and location of air bleed. Suppose that I could cut the fill tube from a new tank and solder on the one from my old tank.
Does anyone know where a new tank for my car can be purchased? Any thoughts about how I should proceed?
Re: Fuel Tank Replacement
Postby Otto Skorzeny » Thu Feb 04, 2021 6:30 pm
I've not been able to locate new tanks for the '66 Toro.
I'd send the best one you have to Gas Tank Renu or use one of the fuel tank sloshing compounds from Eastwood. I used the Eastwood product on a 1964 Galaxie back in the 1990s and it's worked perfectly. No leaks or further rust since.
https://www.gastankrenu.com/
DoodoVage
TOA Membership Number: 612
priligy amazon uk
Postby DoodoVage » Mon Sep 02, 2024 3:46 pm
Eye 1994; 8 Part 4 373 377 <a href=https://enhanceyourlife.mom/>priligy tablet</a>
Lipient
TOA Membership Number: 127
dapoxetine 60 mg forum
Postby Lipient » Thu Nov 07, 2024 1:40 pm
If you take doxycycline mono, and also smoke weed or take MDMA, you can research the effects of doxycycline mono and weed, doxycycline mono and Cocaine as well as doxycycline mono and MDMA here <a href=https://fastpriligy.top/>priligy 30mg</a>
Lipient
priligy and viagra
Postby Lipient » Tue Nov 19, 2024 9:52 pm
how to buy priligy in usa RET aberrations in diverse cancers next generation sequencing of 4, 871 patients
RussBarnes
TOA Membership Number: 5
Years Owned: '67 Toronado
Postby RussBarnes » Sun Jan 12, 2025 4:40 pm
In case you haven't already found a tank, Fusick has new, reproduction ones. They are a perfect fit.
Casinosgigma
TOA Membership Number: 855
automaten online casino f27veh
Postby Casinosgigma » Fri Feb 21, 2025 7:28 am
With thanks, Ample knowledge!
free chips online casino no deposit https://mgmonlinecasino.us/crypto-casinos-usa/ cuГЎl es el mejor casino online
