2. Game Structure
a. Maintain Composure: Keep calm and collected during build-up play. Avoid rushing passes and make sure you have control of the ball. A confident and methodical approach helps prevent mistakes and counter-attacks.
b. Ball Control: Improve your ball control by FC 24 Coins practicing dribbling and maintaining composure under pressure. Effective dribbling helps you keep possession and create opportunities.
c. Safe Passing: Ensure accurate passing by looking in the direction you want to pass. Avoid pressing the pass button too frantically and aim for precision rather than speed.
3. Offence
a. Vary Your Attacks: Avoid predictability by mixing up your attacking strategies. Use a combination of central play, wing play, and long-range shots to keep opponents guessing.
b. Play Through the Centre: Quick passing and skill moves are essential when attacking through the centre. Use sharp passes and dribbling to navigate tight spaces.
c. Exploit the Flanks: Use the wings to stretch the defense and create crossing opportunities. If crossing, aim for accuracy and consider high crosses if you have strong headers in the attack.
d. Shoot from Distance: Don't shy away from FC 24 Coins for sale taking long-range shots. With improved goalkeepers, distance shots can be effective if taken with precision and from the right angle.
Mmoexp FC 24 Coins: Shoot from Distance
Rozemondbell
