new here with 66 toronado
wim 66toronado
Years Owned: 66 toronado, 64 jetstar 88 convertible
Postby wim 66toronado » Sat Dec 22, 2018 11:17 am
Yes, I am the proud owner of a 1966 toronado! From Belgium with some rust issues but when I am finished with this car it will be amazing :-) Missing some parts like side windows, decklid and some other small things... But I will find them and make this car awesome... Also proud owner of a 1964 Jetstar 88 convertible...
Will post pics, but first figure out how this works...
From Holland, Wim
brian66toro
Re: new here with 66 toronado
Postby brian66toro » Sat Dec 22, 2018 2:56 pm
Welcome! Good luck with getting your car back on the road!
Brian
Postby Otto Skorzeny » Sat Dec 22, 2018 5:19 pm
A nice Christmas present for yourself. You've got your work cut out for you.
You should get in touch with Harald Schoener in Germany. He recently finished restoring a '66 Toro and did a fantastic job. Pictures of his work are on this website.
I know where you can get windows, bumpers, body parts.
wim 66toronado
Postby wim 66toronado » Sun Dec 23, 2018 4:58 am
Thanks, I need side windows, a good deck lid and a rustfree drivers door.. Are there any patchpanels available for rocker/quarterpanel??
Thanks Wim
Postby Otto Skorzeny » Sun Dec 23, 2018 6:22 am
No new sheet metal is available as far as I'm aware. You'll have to make them yourself or salvage sheet metal from a rust free donor car.
Go to the Parts Sources page on this forum and find the used parts you need.
Where did you get that Toronado? Was it already over in Belgium somewhere?
You may already be aware of these companies:
https://www.fusickautomotiveproducts.com/
https://www.oldsobsolete.com/
wim 66toronado
Postby wim 66toronado » Sun Dec 23, 2018 6:34 am
Bought it here in Holland, but it is assembled in Antwerpen Belgium, that is wat the VIN plate says... Thanks for the tip for parts, I will ask for it in the parts wanted section. It is a the Deluxe version with everything elelectrical, I am almost finished with restoring a 59 dodge, the Olds will be the next..
This is my other Olds..
Postby Otto Skorzeny » Sun Dec 23, 2018 6:38 am
That's nice. Is that the Dodge under the tarp?
Postby Otto Skorzeny » Sun Dec 23, 2018 6:43 am
Here is my Toronado and my '56 Cadillac Coupe de Ville. I use them both as regular transportation. I don't own any modern vehicles.
Postby Otto Skorzeny » Sun Dec 23, 2018 6:48 am
Here is the section I was referring to rather than the Parts Wanted section.
viewforum.php?f=42
John Dorcey has 50 parts cars that you might be able to get the windows and trunk lid from.
wim 66toronado
Postby wim 66toronado » Sun Dec 23, 2018 8:37 am
great cars! and yes that is the dodge about 3 years ago, almost finished now... contacted John Dorcey already, he has a lot of parts for my Toronado he says...
