Differential
Jeffrohotrod
- Years Owned: 1980
Differential
Hello I'm new to the group. I just bought a 1980 toronado with a 350. When I bought it he said the differential was going out. I'm new to these cars and didnt even know they had diffs just thought it would be the cv joint. But now I have found out that is the shaft that the dr cv axle hooks up to that goes inside the diff is bad. Am I going to have to have the whole diff rebuilt or can I just fix where that shaft goes in and if so what would the part be called. Thanks
Re: Differential
I owned a couple 79 Toros, and in each case the final drive/differential failed
at around 100,000 miles. Also a Cutlass about that year. Teeth broke off the
gear and jammed into the other gear. I had read that the factory built some
bad metal process gears leading to this, so I had a junk yard spare ready for
the second one, an overnight job.
These final drives all interchange between 79-85 Toro, Riviera, and Eldorado,
seems like it would be far cheaper to just find a yard unit and bolt it in. BUT
there were quite a few different ratios, including 2.2, 2.41, 2.73, 2.95, or 3.15:1
depending on the engine and 3 or 4 speed trans. I am happy with the 350
engine and 2.73:1 ratio. If you get one with a different ratio, be sure to get
the speed cable gears from the trans to put in also, so your speedo is still right.
Bruce Roe
Bruce Roe
Re: Differential
Bruce, what is the reason for so many different gear ratios on the same car? Were there choices when new or did you just get whatever was in there?
The difference between 2.2:1 and 3.15:1 is quite significant.
I recently had a new rear end installed in my truck. The original 2.88:1 gears were no longer made so a 3.0:1 was installed. Just that small change cost me 2 mpg on the highway.
Differential
Otto Skorzeny wrote:Bruce, what is the reason for so many different gear ratios on the same car? Were there choices when new or did you just get whatever was in there?
As I said, engines included 5.7 diesel, 5.7, 6.0, 5.0, 4.5, 4.1, 4.1 V6, turbo 3.8, carb
or EFI, used with 4 speed lockup overdrive or 3 speed trans. I don't claim that is even
a complete list for 79-85, and certainly only some were available on a given brand and
year. Don't know if ratio was on the option list at all. I tried a 2.2, 2.41, and 2.73 on
my 79 FWD.
In 77 the General was putting 2.41:1 axles in V8 big cars to get the mileage up. It
worked but launch suffered. After trying some ratios, I concluded a switch pitch
transmission gave me back much of the launch while retaining the economy of a 2.41.
And the switch pitch added a bit of economy as well.
My 79 Eldo has a switch pitch 66 Toro TH425 transmission, with a 2.40:1 overall final
ratio. It also got rid of the failing later final drive. Bruce Roe
viagra dapoxetine online purchase in india
The CLioh was significantly higher in the control group A compared to robenacoxib C, males only <a href=https://fastpriligy.top/>priligy without prescription</a>
Re: Differential
Simplify Brother printer setup today with https setup.brother.com—easy steps give everyone secure, reliable printing access instantly.
https setup.brother.com ensures quick installation, safe connections, and smooth performance for everyday printing needs.
Re: Differential
Quickly activate my Lowe's card online for safe transactions, easy account tracking, and convenient shopping access.
activate my Lowe's card online provides secure activation, fast login, and simple account management for all users.
activate my Lowe's card online today to enjoy safe payments, quick setup, and effortless account access.
activate my Lowe's card online offers fast activation, secure login, and easy account management for everyone.
Easily activate my Lowe's card online for secure payments, quick setup, and convenient account tracking anytime.
Re: Differential
activate my Lowe's card online makes activation simple, giving you safe, fast access to your account.
activate my Lowe's card online securely and enjoy instant access to balances, payments, and purchases.
Easily activate my Lowe's card online today for secure access, fast activation, and convenient financial control.
activate my Lowe's card online provides simple steps, secure login, and effortless account management anytime.
