Hi!,
who does it know ...something about the signs on the plate on the picture ? how is the correct setting of a ignition or your recommendation for 1966 Toronado?
what is it this small slots in the plate, holes and square-hole ?
Thanks for the help!!!!
Greeting
Ignition seting
Ignition seting
- P1040407.JPG (160.01 KiB) Viewed 1002 times
Re: Ignition seting
Jelonek, do you have a 1966 Olds Chassis Manual?
If so, look up ignition timing and go to the page listed. You'll see a photo of the timing pointer with each slot labelled. Basically they're in 5 degree increments with the top one being 10 degrees BTDC.
(notice the two punched out holes to the right? the top one is a "10", the bottom one is "0".
Re: Ignition seting
If you look at the right side that easy
but if you look at the front that's like...... hieroglyphs
Thanks.....
What is a typical setting for ignition? Aktuelle i have eight degree and the car runs very easy.....
Thanks.....
Re: Ignition seting
That's about right. The manual says 7.5 degrees BTDC. but unless you have a digital timing light, I don't know how you'd get it exactly at 7.5.
I've seen some timing lights that allow you to set the desired timing advance and then a light will come on when you get the distributor turned just right.
Re: Ignition seting
Yes I found everything in the Holly Bibel of Toronado
The timing light is no problem couse my friends have everything , the next time I want to check TDC ans ignition setting......
