Ignition seting
Jelonek
Years Owned: 1
Ignition seting
Postby Jelonek » Wed Jul 04, 2018 10:42 am
Hi!,
who does it know ...something about the signs on the plate on the picture ? how is the correct setting of a ignition or your recommendation for 1966 Toronado?
what is it this small slots in the plate, holes and square-hole ?
Thanks for the help!!!!
Greeting
Re: Ignition seting
Postby Otto Skorzeny » Thu Jul 05, 2018 8:50 am
Jelonek, do you have a 1966 Olds Chassis Manual?
If so, look up ignition timing and go to the page listed. You'll see a photo of the timing pointer with each slot labelled. Basically they're in 5 degree increments with the top one being 10 degrees BTDC.
(notice the two punched out holes to the right? the top one is a "10", the bottom one is "0".
Jelonek
Years Owned: 1
Re: Ignition seting
Postby Jelonek » Fri Jul 06, 2018 7:56 am
If you look at the right side that easy :lol: but if you look at the front that's like...... hieroglyphs
Thanks.....
What is a typical setting for ignition? Aktuelle i have eight degree and the car runs very easy.....
Re: Ignition seting
Postby Otto Skorzeny » Fri Jul 06, 2018 8:11 am
That's about right. The manual says 7.5 degrees BTDC. but unless you have a digital timing light, I don't know how you'd get it exactly at 7.5.
I've seen some timing lights that allow you to set the desired timing advance and then a light will come on when you get the distributor turned just right.
Jelonek
Years Owned: 1
Re: Ignition seting
Postby Jelonek » Fri Jul 06, 2018 9:34 am
Yes I found everything in the Holly Bibel of Toronado :oops:
The timing light is no problem couse my friends have everything , the next time I want to check TDC ans ignition setting......
