1966 Toronado transmission problems!
classicarsva
TOA Membership Number: 1305
Years Owned: 1966 toronado deluxe
Postby classicarsva » Sat Jun 30, 2018 2:48 pm
Hi Guys,
I purchased a very nice older restoration that had not been used much since work was stopped.
It has 80,840 miles and looks, runs and drives very nice EXCEPT!! The transmission will not upshift automatically. From a stop, it starts forward in DRIVE. It’s like a manual trans being stuck in 4 gear. I am a retired restoration mechanic and very familiar with older cars which have sat around so,
Here’s what I know or have done:
1) Oil level is clean and full when hot in park.
2) Trans will start in low and upshift just fine using manual shifter on column!!
3) Reverse works as it should.
4) I removed non-functional factory kickdown switch assy. from engine and installed Bruce Roe’s electronic switch and 1968 gas pedal assy. Switch pitch and kickdown now work great!
5) I replaced the vacuum modulator and confirmed 15-18 units of vacuum at the transmission.
6) I removed the Governor and confirmed the plastic gear is in good condition.
7) Cruising along at 60-70, the car drives and feels great! I am stumped!!! Help?
I am not familiar enough with this transmission or TH-400’s in general so if anybody has a suggestion or direction for me to try, I’m all ears. Failing that, does anyone know of a transmission shop in central Virginia who has the knowledge to R&R and correctly rebuild a Toronado transmission?
Thanks,
Garland Gentry #1305
(540) 642-6335 (cell and text)
Culpeper, VA
Postby bcroe » Sun Jul 01, 2018 11:27 am
So the car starts in drive, not the usual problems of slipping or staying in low? My
first guess is the governor is telling the trans to upshift, make sure its seated
properly after any service (not so easy to do). Or try another governor.
Next suspect is the valve body. Since the trans can be shifted into any gear
manually, the rotating parts may be OK. Bruce Roe
classicarsva
Re: 1966 Toronado transmission problems!
Postby classicarsva » Mon Jul 02, 2018 8:26 am
Hi Bruce,
Though I could not figure out how to remove the governor weights from the "cup" housing, they seemed to move freely and the valve moved up and down smoothly. Do I assume correctly that the shaft orientation makes no difference
as long as you get the plastic tooth gear to mesh properly?
You are correct, NO upshifts to any gear. Starts forward in drive and you can feel the strain of the transmission trying to move 5000 lbs! Downshift with the Kickdown switch works correctly with no hesitation.
Even though I replaced the Vacuum Modulator valve, is it possible to remove the pushrod in the transmission case to be sure it and the internal valve are clean and moving smoothly? if so, how?
I assume the main valve body can be removed by dropping the pan and leaving the trans in place on the car. Can any transmission shop rebuild these or are rebuilt ones available (for TH-425 !!)?
Thanks or your help Bruce. Love your electronic switch!
Take Care,
Garland Gentry
Postby bcroe » Mon Jul 02, 2018 10:09 am
classicarsva wrote:Hi Bruce,
Take Care, Garland Gentry
No alignment req for the governor, but with that flat rubber seal its hard to
get it properly sealed. I can't get mine apart either, keep thinking about a
custom outer case so I could get in for tuning. Its likely OK.
When the Vac Mod is removed (and a quart of fluid spills out), there is a
moving valve just inside, which should easily slide straight out given
enough clearance in your car. The valve body and restrictor plate on a
switch pitch 66-67 are different from later years. If you had a spare and
could go through it, I think it could be swapped for comparison using guide
pins and a couple other tricks. Only done it on a TH400 here. Not having a
spare means disabling the car while going through this unit. I expect a
problem there since all gears work in some modes, but I am not an expert
on all 400/425 failure modes. Maybe some research could turn this up.
Here at some point I jerk the trans and put in my backup, not so easy if
you don't have the right equipment. Others likely will go to a shop,
who will have no concept of switch pitch. Put in writing that this feature
must be retained as before.
Glad the switch Pitch Controller is doing the job for you, it would be even harder
to get started without it. good luck, Bruce Roe
DoodoVage
TOA Membership Number: 612
where to buy dapoxetine in malaysia
Postby DoodoVage » Fri Aug 30, 2024 11:30 am
<a href=https://enhanceyourlife.mom/>can you buy priligy</a> In this study, we demonstrated that Nar could directly target signal transducer and activator of transcription 3 STAT3 and significantly inhibit its phosphorylation, which has not yet been reported
Casinosgigma
TOA Membership Number: 855
online casino malaysia 2024 c46flb
Postby Casinosgigma » Fri Feb 21, 2025 7:08 am
Nicely put, Thank you!
new vegas online casino no deposit bonus https://eseomail.com/mybookie-app/ online pennsylvania casino
Play free casino games online crash casino game air casino online!
luis01
Postby luis01 » Mon Jun 30, 2025 4:45 am
Brother printers are a range of printing devices manufactured by Brother Industries, a multinational electronics and electrical equipment company.To download Brother printer drivers, Go to the Brother printer drivers website.
Use Brother printer drivers for better printing results. Customize print options, manage colors, handle various media, and integrate seamlessly with networks and software. Enhance productivity and security with easy-to-use features.
Visit Brother printer drivers for easy-to-follow solutions to fix problems when installing Brother printer drivers. We'll guide you step-by-step to get your printer up and running smoothly.
Streamline your printing experience by installing Brother printer drivers effortlessly. Access the latest drivers tailored to your printer model and operating system via the Brother printer drivers website.
Brother printer drivers provide advanced printing options, including duplex printing and color management, empowering users to customize their printing experience for optimal results.
Go to the support section of the Brother printer drivers website to start the process of downloading and installing Brother printer drivers.
When it comes to quality, reliability, and productivity, the Brother IJ printers are the first and only choice of the users around the globe. It is a one-stop solution for multiple tasks that you can easily execute after the setup on your device. Brother printer drivers is the web portal provided by Brother so that the users can Download Driver, Manual setup and for their Brother Printer.
Brother Printer Drivers are essential software that enables your Brother printer to communicate with your computer or device.
Go to Brother Printer Drivers are essential software programs that allow your computer to communicate with your Brother printer. Without the correct drivers, your printer may not function properly, leading to printing errors, connectivity issues, or reduced performance.
luis01
luis01
Postby luis01 » Mon Jun 30, 2025 4:48 am
Setting up your Brother printer is a simple process when you follow the right steps. By unboxing the printer, connecting it to power, installing ink cartridges, loading paper, and connecting to Wi-Fi, you’ll have your printer ready to use quickly. VISIT Brother Printer Drivers now.
Brother Printer Drivers are known for their reliability and high-quality performance. Setting up your printer involves opening it up, connecting power, installing cartridges, loading paper, and configuring it for USB or wireless use. Installing the latest drivers ensures smooth operation.
Brother Printer Drivers are software programs that facilitate communication between a computer or other device and a Brother printer.
how to effortlessly connect your Brother printer to Wi-Fi and enjoy the freedom of wireless printing. visit Brother Printer Drivers now.
Brother Printer Drivers are known for their reliability, high-quality print outputs, and user-friendly features. However, like any piece of technology, they require regular maintenance to function at their best. Proper setup and care not only ensure smooth operations but also help you get the most out of your device over the years.
Brother Printer Drivers act as a bridge between your computer and the printer. They help translate the commands from your computer into a format your printer understands. Without the correct drivers, your printer may not function properly or may not work at all.
To install Brother printer drivers, first, visit the Brother Printer Drivers website and navigate to the "Support" section. Then, enter your printer model and operating system details. Download the appropriate driver package and follow the on-screen instructions for installation. Typically, this involves running the downloaded file and following the prompts provided by the installer. Once the installation is complete, connect your Brother printer to your computer via USB or network, and your system should automatically detect and configure the printer with the newly installed drivers.
Brother Printer Drivers play a vital role in ensuring smooth and efficient operation of Brother printers, offering a range of features and functionalities to meet the diverse needs of users.
Brother Printer Drivers are software programs that facilitate communication between a computer and a Brother printer. These drivers act as intermediaries, translating data from the computer into a format that the printer can understand and execute. To download Brother printer drivers, Go to the Brother printer drivers website.
Unlock the best performance of your Brother Printer Drivers with our easy driver download center. Whether you are setting up a new device or updating an old one, our platform makes the installation simple and quick. Get the latest updates and enjoy smooth, high-quality printing every time at brother printer setup.
luis01
Explore Brother Printer Drivers to learn more about our extensive service offering, enduring history, and guiding principles. Take a look at our journey and discover our dedication to quality.
With Brother Printer Drivers, setting up your Brother printer is easy. The required software and drivers for your Brother printer can be downloaded and installed with the help of this website. This is how to begin:
We are your trustworthy partner when it comes to setting up a Brother Printer Drivers. We guarantee a flawless installation and top-notch performance for your printing requirements with our knowledge and commitment.
To set up your Brother printer using Brother Printer Drivers, start by unboxing and preparing the printer, installing cartridges, and loading paper. Power on the printer and connect it to your network via Ethernet or Wi-Fi. Next, visit setup.brother.com on your computer or mobile device, enter your printer model, and download the Full Driver & Software Package for your operating system.
We recognize the value of a hassle-free printing experience at Brother Printer Drivers. Our portal is made to give you information and simple-to-follow instructions so you can easily set up your Brother printer. Our comprehensive instructions guarantee that you will quickly get your printer up and running, regardless of whether you're a first-time user or want to reconfigure your equipment.
Brother offers Brother Printer Drivers as a centralized platform for users to access resources and tools for setting up and configuring their Brother devices. There are some typical features and details you might find on Setup.brother.com:
The website for configuring Brother printers is Brother Printer Drivers. The drivers and software required for your Brother printer may be downloaded and installed with ease using the simple instructions found on this website. Users may rapidly install their printer and ensure compatibility and best performance by visiting setup.brother.com.
To download Brother printer drivers, choose the correct version from the website. Whether you are using Windows or Mac, "Brother Printer Drivers" help you to increase the performance of your printer.
brother printer drivers You can visit the website of Brother to download brother printer drivers . These drivers are available for Windows, macOS and Linux systems and help all the functions of the printer to work properly.
Users browsing this forum: No registered users and 20 guests
