Turn signals
Toronadotrofeo
TOA Membership Number: 24
Years Owned: 1966 toronado
1981 toronado
1990 toronado
1991 toronado
1992 toronado
Turn signals
Postby Toronadotrofeo » Thu May 10, 2018 8:18 pm
Hi everyone I need a little help
Before I dropped the steering wheel column to remove the dash my turn signal both worked now only the drivers side works
I have tilt tel steering column
I can figure it out
Mikel
TOA Membership Number: 100
Re: Turn signals
Postby Mikel » Fri May 11, 2018 9:34 am
The turn signal switch in a '66 is external, driven by a cable. It's very likely that the switch has been knocked out of alignment.
Jelonek
Years Owned: 1
Re: Turn signals
Postby Jelonek » Fri May 11, 2018 10:53 am
See to my tread, i repared that's
Jelonek
Years Owned: 1
Re: Turn signals
Postby Jelonek » Fri May 11, 2018 10:55 am
You have to put it inside in the middle Position you can find how to do it in Service book and this is a very important cause if you don't to it like this you have a light only on one side
Toronadotrofeo
1981 toronado
1990 toronado
1991 toronado
1992 toronado
Re: Turn signals
Postby Toronadotrofeo » Fri May 11, 2018 4:30 pm
I’ll try that thank you
