Wheels
Mrtoro67
TOA Membership Number: 1322
Years Owned: 1967 Olds Toronado
Wheels
Postby Mrtoro67 » Mon Apr 16, 2018 3:42 pm
Finally got the wheels on La Sancha looks pretty good. :roll:
Mrtoro67
Re: Wheels
Postby Mrtoro67 » Mon Apr 16, 2018 3:45 pm
Mrtoro67
Re: Wheels
Postby Mrtoro67 » Mon Apr 16, 2018 3:51 pm
More
Re: Wheels
Postby Otto Skorzeny » Tue Apr 17, 2018 12:54 pm
Not bad looking. Those are the ones you had custom made, right? What size rim and tire?
What did they charge to make those for you?
Mrtoro67
Re: Wheels
Postby Mrtoro67 » Wed Apr 18, 2018 8:56 pm
They are 17 x8 with Michelin 235/65-17 104H. They are not custom made just drilled and machine with a large offset. I am only in to them wheels and tires about $1,800. All done. I think it was a good deal. They still sit out a bit more then I like but don't seem to be putting to much pressure on the bearings. Time will tell. :roll:
Re: Wheels
Postby Otto Skorzeny » Thu Apr 19, 2018 4:55 am
That's pretty cool that you found an Olds center cap emblem that fit them.
These are the specs for Toro wheels so you can compare the backspace and offset measurements.
Bolt Pattern 5 on 5"
Width 6 inches
Offset +3.25 inches
Backspacing 6.75 inches
Load Rating 1600 pounds
Jelonek
Years Owned: 1
Re: Wheels
Postby Jelonek » Sat Apr 21, 2018 12:45 am
very very very cool !! 8-)
Mrtoro67
Re: Wheels
Postby Mrtoro67 » Thu Apr 26, 2018 3:26 am
Thanks
mindreader45
Re: Wheels
Postby mindreader45 » Thu Jul 19, 2018 6:17 am
Nice rims!
Eightballz
TOA Membership Number: 826
Re: Wheels
Postby Eightballz » Wed Aug 01, 2018 10:45 pm
totally interested in your cowl hood.
could you maybe post some pictures from the underside of the hood? also how did you mount the cowl scoop?
what brand / dimension did you used?
