Headlamp Check Valve
bstone63
- Years Owned: 66 Toronado
I'm pretty sure I found out why my headlamps won't open. Instead of the check valve that is connected to the vac source, vac tank, and headlamp switch, there is just a regular tee fitting. Does anyone know of a replacement part? I can't find the GM 394420 anywhere.
bstone63
Re: Headlamp Check Valve
Fixed!!
Bought a $5 check valve from a local parts store and they started to open. A couple of snips on the ends of a couple other vacuum lines and voila! Plus I now have heat as well.
Good deal!
Can you post a picture of the repair? Where was the valve? What year toro?
