Makin' it happen
1970w34
TOA Membership Number: 38
Years Owned: 1970 multiple
Re: Makin' it happen
Postby 1970w34 » Mon Sep 25, 2017 7:40 am
I did have to sort through and reuse, I think the uppers, because the new ones didn't fit properly. I'll check and let you know for sure later.
Eightballz
TOA Membership Number: 826
Postby Eightballz » Tue Sep 26, 2017 12:04 am
Otto Skorzeny wrote:No. I haven't had to redo my suspension.
Are they too small in diameter or too short? What did you do? What did Steele say about it?
Were you able to find the correct size elsewhere?
the factory bushings are around 1- 5/8"in diameter, the ones they are selling are only 1-1/2" (part# 70-3345-35). they told me theres no way they wont fit since their catalog states they will. :evil:
they also told me i should compare the dimensions i need with bushings they sell for other brands/models..maybe another one will meet my requirements.
they offered a refund though
Postby Otto Skorzeny » Tue Sep 26, 2017 4:38 am
It's in the catalog so it must be true! That's pretty dumb. I'd have expected them to ask for more details so they can check their product and make corrections if necessary.
I'm sure you two guys aren't the only customers who have returned them. I wonder if later models used smaller diameter bushings and Steele just assumed the same size was used in all years?
1970w34
Postby 1970w34 » Tue Sep 26, 2017 6:47 am
Yeah, it's the uppers....the square rear body to frame mounts are also a bit off sized but they can work.
I have a NOS rear body to frame mount and it's about 1/4 inch thicker than the Steele product but I simply made a shim with 1/4 black nylon stock and drilled the proper sized hole in order to get the correct thickness. This will probably end up more durable anyway as it is on the bottom where most of the distortion and damage occurs.
MNfirefighter
TOA Membership Number: 1
Years Owned: 1966 Toronado Deluxe - all original - white exterior w/ plum interior
Postby MNfirefighter » Tue Oct 24, 2017 2:49 pm
Love all the pictures! I'll keep following the progress and dreaming of when I can do this to my toro. It's looking really good!
Postby Doc Hubler » Tue Oct 24, 2017 8:56 pm
I did use the bushing replacements for the rear springs, and pretty sure they were a tight fit and that I got them from Steele; the issue was getting them in, not that they were too small. I will have to go back and see what we used when we redid them a couple of years ago. I thougtht they were fine.
Users browsing this forum: No registered users and 91 guests
