Trying to verify identity on a 70 GT.
Where is the C located on the head casting that identifies the correct cyl heads?
GT heads casting mark
guardrail22
- Eightballz
- TOA Membership Number: 826
Re: GT heads casting mark
head code of a 1970 GT should be "E".
its got the big valve E-heads and the letter should be found on drivers side. you may remove the alternator brackets to gain access
guardrail22
ok. Got it
can't seem to paste in picture. Have that and the OM trans code
