shorter water pump?
gearhead840
shorter water pump?
Postby gearhead840 » Thu Apr 15, 2010 3:42 pm
i was hoping someone could clue me in on long shaft water pump vs. short shaft and pullies. I think the short shaft pump and correct pulley, along with the radiator core support from a 69 toro welded in will solve my 4 core radiator blues. I would really appreciate your help.
I know i will still have to modify the radiator cap for the larger drivers side tank, but one challenge at a time.
toro_mike
Contact:
Re: shorter water pump?
Postby toro_mike » Wed Apr 21, 2010 9:09 am
Bumping to get this one noticed...
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
gearhead840
Postby gearhead840 » Sat May 15, 2010 9:28 pm
well the larger 4 core radiator is in, We had to weld in a radiator support from a 69 toro, and massage the top cover to fit the larger tank. a little weld, a little sheet metal and the tiniest amount of bondo made it look like it belonged there all along. I have a solid 3/4 inch clearance between the fan and the rad. a shorter fan clutch would be heaven but I will take what i can get. Now onto the disc brake conversion
