I am in the process of finishing a new wiring harness install, but the owner before me removed all the behind the dash wiring and threw it away. Now I do not have the plugs for the gauges. I am in desperate need of the following plug ins.
Fuel gauge
Temp Gauge
Oil Pressure light
Amp Gauge
Clock
Headlamp Switch
Cabin Temp Switch and heater Control
Wiper Switch
Rear Defrost Switch
Ignition Switch
66 Toronado Behind Dash Wiring - ASAP
awalgrunt6
Re: 66 Toronado Behind Dash Wiring - ASAP
I would call these two companies and see if they can help you with the correct connectors.
YNZ Yesterday's Parts Complete reproduction wiring harness for all makes and models
http://www.ynzyesterdaysparts.com/
909-798-1498
Rhode Island Wiring Service, Inc. Wiring harnesses for all years, all makes and models
567 Liberty Lane, PO Box 434
West Kingston, RI 02892
(401) 789-1955
http://www.riwire.com/
909-798-1498
(401) 789-1955
awalgrunt6
I was able to find a complete set of harnesses on ebay that will work nicely. Much cheaper than 750.00 for a new harness. Thank You!
