Serpentine Belt Conversion
Re: Serpentine Belt Conversion
Postby xgecko » Thu Jun 19, 2014 6:09 am
It looks like I may have to hold off on the B&M shifter. :( The fixed throw of the cable is not easily matched to the shift lever on the transmission - complicated by the lack of a full straight path for mounting due to the part of the housing required for the drive chain (link-belt, if you prefer) getting in the way.
I will need to spend some time determining what angle and what bracket configuration will work and I need to get the motor back into the car by next weekend (not the upcoming weekend).
I have a friend that has a TH-425 Switch Pitch I will be trading a cam and lifters for so can use that as the development mule while the current trans is in the car.
The price of bleeding edge modifications to a car that is not very common. While we have many benefits of not having a Chevelle, Mustang or Camaro, we do pay a price in other ways. I was watching a car show last night where a guy bought a '68 Camaro for $12,500. My car was in far better condition when I bought it for $3,250. I can live with the issues that arise from an uncommon car.
Especially when I see the reaction of people when the not only see a Toronado only to realize it is also a Hot Rod. Priceless indeed! 8-)
Postby xgecko » Mon Jun 30, 2014 5:52 am
This says it all:
1977 Cutly
TOA Membership Number: 1059
Years Owned: 1966 Toronados
1977 Cutlass Supreme
Postby 1977 Cutly » Mon Jun 30, 2014 10:50 am
Hello new wallpaper!
Thanks for the pic, that really looks awesome
Postby xgecko » Mon Jun 30, 2014 11:07 am
One of the most cool features - pun intended - is that the AC compressor is much shorter than the original as well as drawing only 3HP vs the 12HP that the original unit required. I found this out when I asked about the idle kickup feature my EFI has; they told me I don't need it.
Once I get the AC Condenser installed I will know how well this new kit runs. I am really looking forward to the improvement!
gmrocket
TOA Membership Number: 880
Years Owned: 1967 Toronado Deluxe - owned this car since 1995 and am the second owner. Sadly it was cosmetically gorgeous but mechanically and electrically a mess when I got it. It was a feature car at the 1997 Olds Centennial but still wasn't running right then until Sparky Kalkhoff and I swapped out the wrong cam for the correct original. Everything electrical was repaired over the years until the point where the cosmetics became a mess. It's now undergoing its second restoration with lots of new metal to address years of rot courtesy of its Northeast PA roots.
Postby gmrocket » Fri Jul 04, 2014 8:39 am
Holy crap, xgecko, that looks incredible! Tell me more about the a/c compressor - I have the original Harrison unit that worked great when I started my resto but is obviously an R12 unit (ugh). Also, any mods needed for the power steering pump or anything else to know to do the serpentine belt set-up? Finally, what intake manifold is that under your MSD EFI? Thanks in advance - inquiring minds need to know! :shock:
Gregg L
TOA #880
'67 Deluxe
Postby xgecko » Fri Jul 04, 2014 11:43 am
Hi Greg,
That is a Sanden AC unit that came with the Serpentine kit. By purchasing it along with the Cold Aire Products kit I got 10% off both. That amounts to roughly $300 so it is a good deal.
My kit has a remote reservoir steering pump so keep that in mind.
I used the Rockwell aluminum Toronado intake under the Atomic EFI. You can get one at Mondello or Applied GMC.
I am on my way out to go camping so feel free to ask anything else you want but keep in mind I will be back next week.
Checkov
Postby Checkov » Mon Nov 17, 2014 10:23 am
Haha
Postby xgecko » Mon Nov 17, 2014 10:27 am
You really have no idea...
It took something like 6 or 7 tries to get the correct belt if you include the initial tests with Gates belts and my choice to settle on Gatorback belts...
UV520
Postby UV520 » Thu Sep 22, 2016 6:50 am
Hello Xgecko,
Any update on your serpentine belt setup?
I have not found anything yet. But I am doing more searches on this forum.
Thank you, Tony
Postby Otto Skorzeny » Thu Sep 22, 2016 2:58 pm
Tony, you might want to send Gecko a PM or email. I haven't seen him post here for a while.
Users browsing this forum: No registered users and 113 guests
