Purple plug to nowhere
project02
- Years Owned: 1969 toronado
I was doing some work under the dash today and I noticed a plug not connected to anything. I has two purple wires leading into it and it looks to be factory wiring. The previous owner had a wire connected to both ends of the plug to apparently complete a circuit. Does anybody know if this plug does anything? I will try to get a photo of it later.
1977 Cutly
- TOA Membership Number: 1059
- Years Owned: 1966 Toronados
1977 Cutlass Supreme
Re: Purple plug to nowhere
I'd like to help but need more to go on. Pics would be much help
- gmrocket
- TOA Membership Number: 880
Dusting off some cobwebs here but possibly it goes to cornering lamps maybe? I recall the same two-wire plug in mine up under the dash at one time and nuking it out to that application. I'll check my manual when I get the chance.
Gregg L
TOA #880
'67 Deluxe
TOA #880
'67 Deluxe
