66 Toro dash turn signal light
425toro
TOA Membership Number: 964
Postby 425toro » Sun Dec 01, 2013 4:27 pm
I had to remove my instrument cluster to fix some wiring issues. As long as I have it out I am going to replace all the bulbs and give it a good clean up. The green lens or "filter" needs to be replaced for the turn signal indicators. Any tips on where to get something that will work? Thanks, Mark
Eyesells
Re: 66 Toro dash turn signal light
Postby Eyesells » Thu Jan 12, 2017 11:12 am
I'm debating on new guages or fix. I need to know what bulb number you used. Any info gleened from your expierence would be appreciated.
MNfirefighter
TOA Membership Number: 1
Years Owned: 1966 Toronado Deluxe - all original - white exterior w/ plum interior
Postby MNfirefighter » Tue Apr 04, 2017 5:15 pm
I've heard of people using just pieces of color plastic that they trim down to fit. Some people have used the little plastic tabs for file folders and items like that. It seems that the plastic dash covers that give those lights their color are not available as replacement parts so people have just made their own. That is a "to do" for my toro so maybe someone else can chime in
