In case anyone is interested, I have a mid-engined '65 Corvair Corsa with a '69 Toronado drive and suspension. The motor I used for the first several years was a '69 Olds 455 with 8 to 1 compression pistons and a fairly mild (260 degree) cam. Later I swapped in a Buick 231 V-6 with a turbocharger blowing into a 500cfm carter carb and used a Mallory ignition system to control the spark curve. It has been off the road for about 7 or 8 years but it should be mobile again soon with any luck. Much as I loved the big Olds motor, the Buick 6 seems to be a better match for the car (and me) from the standpoint of weight balance(handling) cooling, and fuel consumption and rear seat room.
I wanted to pass along some information about custom rims for Toronados that I recently found on-line in case anyone is looking for them. BigWheels.net has several pages of cool wheels in 20" as well as 17 and 18 inch sizes that are supposed to fit these cars, and some of them are fairly reasonable. Let me know if any of this strikes a chord. Thanks...
Toronado powered Corvair
CorvairanadoKid
- Years Owned: '65 Corvair Corsa with Toronado drive and 231 Buick Turbo V-6. Owned for 31 years. Also have '86 T-bird Turbo Coupe and '97 Geo Metro
Re: Toronado powered Corvair
I contacted BigWheels and they are checking with a customer that bought wheels for their Toronado. They will report back to me soon. It would be nice indeed to be able to buy new wheels!
