room for lights
tippecanoe
TOA Membership Number: 155
Years Owned: Hello everyone got one auto..so far 1966 Olds Toronado,Trumphet gold DL.Both my nightmare and my daydream.
room for lights
Postby tippecanoe » Fri Oct 02, 2009 12:20 pm
does anyone know if the seventies high mounted brake lights will fit the opening above the 66 headlights.
lorne6667
TOA Membership Number: 622
Years Owned: 1966 toronado standard
1967 toronado deluxe
Re: room for lights
Postby lorne6667 » Wed Oct 21, 2009 10:24 am
be careful what your getting into.
i have just removed the inserts on my 66,it ain't easy.
headlight doors need to come out,i made a stubby right angle philips driver to gain access to mounting screws.
the inserts can be removed after the light assy. is out of the way.
you will find double panel constuction that may convince you that installing later model taillights may not be such a hot idea, but if your that innovative more power to ya.
the only reason for me to to remove these inserts is that they need to be replaced, i have nice correct ones to install, the black inset i used "dupli-color" wrinkle finish paint, it came out nice.
i also used that wrinkle finish bomb on my instument panel with nice results.
good luck,lorne
tippecanoe
Re: room for lights
Postby tippecanoe » Sat Nov 28, 2009 1:19 pm
Hello Lorne thanks for your info,not sure if i can find this paint in Norway but we have one called hammer surface paint.As for the eybrow lights modern diode lights can be made i guess. That would look great even when the pop up lights are raised.
Users browsing this forum: Majestic-12 [Bot] and 21 guests
