1967 Toronado Harmonic Balancer Counterweight
69OldsSpeed
Years Owned: 1969 Oldsmobile Cutlass S
1967 Oldsmobile Toronado
Re: 1967 Toronado Harmonic Balancer Counterweight
Postby 69OldsSpeed » Sat Mar 06, 2021 9:55 am
bcroe wrote:I thought the same balancer fit all Olds V8s, weight differences were taken care
of in the crank weights. Bruce Roe
One would expect that. But if you look at the notes on the various supplier/vendor websites, they usually warn about rebalancing is required for the early 400 and 425 engine applications. If you look at the above picture you will see why. The Mondello literature also mentions this. It is interesting to see how some vendors offer it as a fit for the 425, some don’t offer it as a fit at all, and some offer it as a fit with a note that “a good harmonic balancer shop can rebalance it for you.” LOL. I called around for this type of work and could write a book about the responses I got. Everything from confusion, denial, to the “I don’t want to do it” price.
My engine is still stock, so it doesn’t have an engine specific counterweight requirement. Perhaps when I rebuild it one day, it will get a properly balanced rotating assembly.
gmrocket
TOA Membership Number: 880
Years Owned: 1967 Toronado Deluxe - owned this car since 1995 and am the second owner. Sadly it was cosmetically gorgeous but mechanically and electrically a mess when I got it. It was a feature car at the 1997 Olds Centennial but still wasn't running right then until Sparky Kalkhoff and I swapped out the wrong cam for the correct original. Everything electrical was repaired over the years until the point where the cosmetics became a mess. It's now undergoing its second restoration with lots of new metal to address years of rot courtesy of its Northeast PA roots.
Postby gmrocket » Thu Apr 10, 2025 7:59 am
Reading this 4 years after the fact as I'm shopping for a replacement harmonic balancer for my '67. What were the results of your install and running experience? Thanks in advance!
Gregg L
TOA #880
'67 Deluxe
69OldsSpeed
Postby 69OldsSpeed » Sat Sep 27, 2025 3:40 pm
My experience was good. I have had not issues since.
