Engine problem 1966 Toronado
Slick66
Re: Engine problem 1966 Toronado
Postby Slick66 » Sat Aug 24, 2024 7:29 pm
Is that the piston head? If it came out that clean then you had a head gasket leak. Is the piston scored? It looks that way in the picture.
Jelonek
Years Owned: 1
Postby Jelonek » Sun Aug 25, 2024 5:01 am
Nr 6 is the Problem :oops:
No, I am looking for a hub in Germany for specialist who can do it
Jelonek
Years Owned: 1
Postby Jelonek » Wed Aug 28, 2024 1:50 pm
Hello all, Toro guys
I need your help. Would you like to tell me if I can put down the engine without to touch the transmission? Where is the suspension of transmission?
after put down The engine is transmission and differential fully stable or I need a special equipment to protect it?
To take off the engine I need at the front two screws on the right side two screws and on the left side … the rest are only a screw on transmission
is That right or the fix points …on another position
With best regards
Wojtek
Jelonek
Years Owned: 1
Postby Jelonek » Thu Aug 29, 2024 10:13 am
No idea? :shock:
Jelonek
Years Owned: 1
Postby Jelonek » Sat Sep 21, 2024 11:26 pm
Update…. The engine is in the engine-clinic and I wait for some information from mechanics
Slick66
Postby Slick66 » Sun Sep 22, 2024 9:06 pm
Hi Jelonek, you can take out only the engine but you must securely support the transmission. You do not want the transmission to move down at all. I belive there is some unbolting to do near the axles/differentials. Also take special note of the front engine mount.
Slick66
Postby Slick66 » Mon Sep 23, 2024 12:54 pm
Make sure to buy volume 1 and 2. They come in a set. Everything specific to the Toronado is in the second book.
Slick66
Postby Slick66 » Mon Sep 23, 2024 4:27 pm
Slick66
Postby Slick66 » Mon Sep 23, 2024 4:47 pm
Slick66
Postby Slick66 » Mon Sep 23, 2024 4:49 pm
