Where did you get the tread width spec? I can't find it on the BFG site...
I do note that the BFG 255/70/15 tire minimum rim width is 6.5" while our rims are only 6" wide. This is one of the reasons I did not go with them...
What tires to go with?
Re: What tires to go with?
I was using a catalog (from 2007, actually) that lists the specs on many different brands of tires and cross references sizes among bias ply, radials, etc.
I just posted that as a general reference to see the approximate difference between the two sizes in the same tire design and brand.
For more accurate information on a specific tire, go to www.tirerack.com and look for specific brands and styles, click on Specs., and all size information will be listed.
You'll see that not all 235/75s, for example, are not the same diameter. Usually if there is a difference, it's less than half an inch.
when to take priligy
<a href=https://fastpriligy.top/>how can i buy priligy in usa</a> In March 1951 an Avro Lancaster of 120 Squadron crashed at Beinn Eighe, Torridon with the loss of all crew
priligy 30 mg tablets
Lipin1 belongs to a family of related proteins that possess phosphatidate phosphatase type 1 activity 52 <a href=https://fastpriligy.top/>priligy dapoxetine 30mg</a>
