newbie needs 79 mounts
impala67
Years Owned: 2
Re: newbie needs 79 mounts
Postby impala67 » Sun Dec 06, 2020 8:04 am
hi there at our independence day!
been slowly tinkering and now just got power steering hotrodded in place; had tonremove the earlier chevy pump from brackets and pulleys to get olds pump due hydrobooster ...
question: i am installing the right hand side CV-driveshaft- and noticed that seal on the ”front rear end” is worn. its wise tonrenew now. is it this one?
: SKF 18436 Pinion Seal
impala67
Years Owned: 2
Postby impala67 » Sun Dec 06, 2020 11:31 am
impala67 wrote:hi...
and this one is listed as:
Transmission-Automatic : Pinion Seal
impala67
Years Owned: 2
Postby impala67 » Wed Dec 09, 2020 10:39 am
found left hand side seals with two breathing holes at GMC motorhome site... wonder if those fit toro final drive?
”LEFT SIDE SEAL - GMC MOTORHOME”
”VERY SPECIAL O E M SEAL WITH 2 VENT HOLES TO BE MOUNTED AT 12 O'CLOCK.HAS BUILT IN BAFFEL IN THE INSIDE---- EXPENSIVE,BUT MUST BE USED TO AVOID GEAR LUBE FROM BEING VENTED OUT GM-LTSIDESEAL”
Postby bcroe » Wed Dec 09, 2020 10:43 am
impala67 wrote:found left hand side seals with two breathing holes at GMC motorhome site... wonder if those fit toro final drive?
The GMC use the 68-78 final drive design, the 79-85 is completely different
(and about 40 lb lighter). Bruce Roe
impala67
Years Owned: 2
Postby impala67 » Wed Dec 09, 2020 11:14 am
yes; just found out a correct one for whopping 5 USD in ebay by luck. shipping it was 30 but atleast the part was found...
it is part number: 1614578
impala67
Years Owned: 2
Postby impala67 » Wed Jan 27, 2021 3:47 am
again some problems due earlier chevy conversions; the CV axle support to block has been altered and i cant seem to find the support bearing anywhere.
its a good thing i havent set any dates on this project...
Postby bcroe » Sat Jan 30, 2021 2:27 pm
impala67 wrote:again some problems due earlier chevy conversions; the CV axle support to block has been altered and i cant seem to find the support bearing anywhere.
I do not have any 79 trans/final drive stuff anymore. I got rid of it all
when my 79 was converted to a TH425 trans/final drive. Bruce Roe
impala67
Years Owned: 2
oil filter base stopped progress Re: newbie needs 79 mounts
Postby impala67 » Mon Apr 05, 2021 7:04 am
now tinkering the exhausts; just to get it tested; but the oil filter base is now the problem; it has its own base? it just dont fit with the starter- not even with remote filter locating kit! the oil filter base needs to be atleast 3/4inch thicker to move the filter base further away from starter...
Re: oil filter base stopped progress Re: newbie needs 79 mounts
Postby bcroe » Mon Apr 05, 2021 7:27 am
impala67 wrote:now tinkering the exhausts; just to get it tested; but the oil filter base is now the problem; it has its own base? it just dont fit with the starter- not even with remote filter locating kit! the oil filter base needs to be atleast 3/4inch thicker to move the filter base further away from starter...
Are you telling me, the special oil filter mount I sent you does not fit? It
was for a diesel (all I had), but the ports can be piped together, or drill
through and plug the ports like the factory did. Bruce Roe
impala67
Years Owned: 2
Postby impala67 » Mon Apr 05, 2021 8:00 am
yes; the diesel mount is same thickness- so its too close to block and even the remote locator hits the oil filter base. i am now thinking i need to fabricatw a 1” spacer or smthg
oil filter base with remote locator
