The starter solenoid is sticking. (most likely) You can probably fix it yourself byt taking it apart, cleaning the little disc thing inside, and reinstalling it. The same thing happened to mine a few years ago. I'll look for the photos of the procedure.
Hit the side of the starter with a crowbar or hammer and I'll bet the car will start. It might work for a while and then you'll have to hit it again. Eventually you'll need to fix the solenoid or replace it.
Hello from Germany!
Re: Hello from Germany!
Here are some bad pictures of my solenoid. I took it apart, cleaned everything, wire brushed the little contact disc and put it in upside down so the clean side could get some use.
- DSC04450.JPG (331.14 KiB) Viewed 20142 times
- DSC04449.JPG (419.93 KiB) Viewed 20142 times
More pictures as I found the solenoid.
- DSC04452.JPG (417.5 KiB) Viewed 20142 times
- DSC04451.JPG (364.08 KiB) Viewed 20142 times
Here's the disc after I cleaned it up.
- DSC04454.JPG (284.24 KiB) Viewed 20142 times
- DSC04453.JPG (266.2 KiB) Viewed 20142 times
The other possibility is that the starter gear is hung up on the flywheel (broken teeth or something) but if it didn't make a starter type noise first, the gear probably never contacted the flywheel. My money is on the starter solenoid.
I don´t know how this happened
- ll.jpg (93.23 KiB) Viewed 20138 times
Hello from Germany!
Well a replacement bendix should take care of it, probably a universal part. I
wonder what country made that one?
The flexplate for the 66-67 Toro had a very bad reputation with gear teeth
wear. Better check out yours. After that they made a special one for Toro
with longer teeth to handle the stress. I managed to find enough of them
for all my cars. Unfortunately it won't interchange with the 425 flex plate.
Bruce Roe
Bruce Roe
Thanks, i check it today,
if possibe I want to make Pictures,
Here are two from Rock Auto.
https://www.rockauto.com/en/catalog/old ... drive,4172
I've had bad experiences with Airtex fuel pumps before but don't know anything about the quality of their starter parts. The other brand, Standard, is generally good quality in my experience. But as Bruce said, who knows where this stuff is made anymore?
Where do you normally buy parts for your car in Europe?
And in German, even. https://www.rockauto.com/de/catalog/old ... drive,4172
Hi
today I got my car back.... with a just new starter from a german firm in Hamburg with as parts ... KTS hamburg
in US it costs about 50 $ but in Europe 250 Euro ... so it doesn´t matter, now I have a new one and it works really another... mutch stronger.
but I want to rebuilt the old one and thanks for links with parts from Rockauto,
I think, rebuilt for 10 $ it´s a good deal and I hope to have a lot fun,
the old one of mine looks very new and there is no rust or dust....
I hope to make a good documentation ...
by the way ...I hate everything with electric..
Users browsing this forum: No registered users and 42 guests
