Rear Air Shocks
Re: Rear Air Shocks
Postby Otto Skorzeny » Fri Mar 16, 2018 11:18 am
I put Sensa-Trac on the rear and KBs on the front. They work great.
Why do you want to use air shocks? If your rear springs are worn out, you can get them re-tensioned by Eaton.
Re: Rear Air Shocks
Postby Otto Skorzeny » Sun Mar 18, 2018 5:15 am
Sorry, I made a mistake. The Sensa-Tracs are on my '56 Cadillac. They're gas shocks made by Monroe. The ones I have on the Toro are gas shocks from Gabriel.
Here's a link to another thread with the part numbers including suitable and affordable horizontal shocks. Fusick charges a fortune for the horizontal ones. I found some from another application which meets the specs. They've been on my car for 4 years now and work great.
viewtopic.php?f=48&t=1685
Re: Rear Air Shocks
Postby Otto Skorzeny » Sun Mar 18, 2018 5:27 am
Rock Auto carries all the shocks listed above and lists air shocks for the Toro.
https://www.rockauto.com/en/catalog/old ... orber,7556
Re: Rear Air Shocks
Postby Otto Skorzeny » Mon Mar 19, 2018 2:34 pm
Do you have the specs for the factory shocks?
The measurements given on Rock Auto's site for the extended length of the air shocks ( I'm pretty sure the AC Delco shocks are made by Gabriel as well) are only 1/10th inch shorter than the extended length of the standard gas filled shocks which bolted right up to my car without any difficulty. The compressed length is only 1/2" shorter than the standard gas filled shock absorber.
That difference will not affect performance at all. If you are driving in such a manner that your rear air shocks fully compress, you are abusing your car.
As for why they won't bolt up, the shocks should be installed with the full weight of the car on the suspension, not with the rear wheels hanging free. I installed all the shocks on my '66 Toro in my driveway with no special tools.
Back the car up on ramps and put a jack and jack stands under the suspension. There should be plenty of room for the fully extended shock to fit. Normally when I install shocks on anything, I leave the shock fully compressed with the plastic strap in place. I attach the lower mount then put the washer and bushing on the top shaft.
Aim the shaft at the mounting hole and cut the plastic strap. The shock will extend upward and go right into position.
Re: Rear Air Shocks
Postby Otto Skorzeny » Mon Mar 19, 2018 3:10 pm
With the full weight of the car on the rear suspension, the shocks are neither fully extended nor fully compressed. They are somewhere in between. There is no way that either of the shocks listed would be too short when fully extended to fit your car.
Since your springs are shot, the distance between the lower mount and the upper mount hole should be even shorter than normal making installation even easier.
Re: Rear Air Shocks
Postby Otto Skorzeny » Tue Mar 20, 2018 6:35 pm
That sounds like an Abbot & Costello routine.
So let me see if I got this right. The shocks you tried to install were not shocks designed to fit the Toronado in the first place because of a miscommunication on the part numbers?
Did you end up buying the Gabriel air shocks, then?
Re: Rear Air Shocks
Postby Otto Skorzeny » Wed Mar 21, 2018 6:17 am
Just for general information, Eaton Detroit will re-arch the mono springs for $225 each.
They sell a replacement 4 leaf stack for $279 each.
Users browsing this forum: No registered users and 57 guests
