Hello from Germany!
Re: Hello from Germany!
Postby Otto Skorzeny » Mon Dec 25, 2017 10:03 am
Postby Otto Skorzeny » Mon Dec 25, 2017 10:05 am
Last pic is cruise control delete. It doesn't do anything except take up space.
Second last pic is heat riser valve.
Jelonek
Years Owned: 1
Postby Jelonek » Tue Dec 26, 2017 6:15 am
thank you very mutch! 8-)
Mikel
TOA Membership Number: 100
Postby Mikel » Thu Jan 04, 2018 1:26 pm
Very cool car! Keep us updated on your progress.
Jelonek
Years Owned: 1
Postby Jelonek » Mon Jan 08, 2018 3:34 pm
Hi Guys
Tomorrow I make some picture but now is a very cold and I can't do anything :oops:
I have a problem with electric system...
I have the right indicator but not the left :cry: I check every lights and put a new.. fuse box is ok.
?? Any idea?
My heating radiator has a leakage, lower pipe, afferent from engine, now I have a bypass and very warm gloves :mrgreen:
, to open it ......from inside or engine-site?
More question and picture tomorrow :D
Wojtek
Eightballz
TOA Membership Number: 826
Postby Eightballz » Mon Jan 08, 2018 5:53 pm
maybe a wire came lose somewhere around your cornering lights or side marker
and if you need to replace your heater you have to remove the heater and A/C box from the engine compartment. its kind of a struggle to get to all the bolts but fortunately the engine can stay in the car ;)
Jelonek
Years Owned: 1
Postby Jelonek » Mon Jan 08, 2018 10:19 pm
a wire is ok, no problem, i checked all conections,
Postby Otto Skorzeny » Tue Jan 09, 2018 6:54 am
Clean all the connections with a wire brush or emery cloth even if they look good. You're going to have to trace the wires and look for a cracked or broken wire. Maybe a bad ground wire.
Heater core is replaced from engine side. If your car has air conditioning (which it does), the manual says the hood has to be removed to provide clearance.
Jelonek
Years Owned: 1
Postby Jelonek » Sat Jan 13, 2018 11:10 am
Hi!
all day i spend bei Toronado.... doorlights working now!! :D it look´s very very beauty 8-) somebody cut a cabel in the door ???? on the both sites,
I conect the heater but the engine needs a lot of time to be warm so i san´t check it now .... tomorrow :?:
the wishes-pump is out of order.. but it´s normal, i want to take another one from VW....ordered for the next week...new tubes i took from my aquarium :lol:
how can i change oil in differential ? one screw to put it in i found but where is the screw to drain it???
sorry but i have a lot of questions...
-how can i take of the wonderfull clock? everything must be put down?
- how can i take of the musicspeaker on ther backseat? from insite or from trunk...
Thanks for your help!!!
Wojtek
Jelonek
Years Owned: 1
Postby Jelonek » Sat Jan 13, 2018 12:15 pm
some pix
what´s that?
devilish
doorlights in action :)
