Makin' it happen
1970w34
TOA Membership Number: 38
Years Owned: 1970 multiple
Re: Makin' it happen
Postby 1970w34 » Tue Jul 25, 2017 8:56 am
On to the water pump, core support, rad, exhaust, gas tank...the easy stuff! :D
1970w34
Postby 1970w34 » Mon Aug 21, 2017 10:45 am
Got a bunch of small stuff taken care of but something that I expected to be small was a nightmare...the oil dipstick tube! I nearly wrecked a NOS one! Clean hole, clean, non-corroded, no burr tube, still a pain!
Used a bolt that just fit into the top end and pounded it down. The Toronado tube has a slight bend designed in so it is difficult to get the full force where it is needed. Next time, which I hope never happens but probably will ;) , I'm going to sink the end in a bowl of dry ice for 20 minutes or so, maybe that will contract it enough to make it easier....just a thought.
1970w34
Postby 1970w34 » Wed Sep 13, 2017 6:59 pm
Wondering if anyone knows for sure what finish the gas tank straps are? Are they painted or just plain metal? Been trying to find out with no luck :?
Anyway, I guess I'll do the exhaust to keep things rolling....
1970w34
Postby 1970w34 » Mon Sep 18, 2017 9:30 am
I rebuilt my original Delco Moraine calipers but ran into an issue evenly seating the dust boot. I could not find a suitable tool in order to do this without wrecking the seal edge and the Kent-Moore BT-6808 when found will cost at least 50 or 60 bucks (for a thin disc of aluminum :lol:) so I had to improvise!
A PVC 3x2 reducer coupling that I picked up at Menards for $1.50 can be easily modified to do the job quite nicely. Just Dremel out a small inner ring of plastic to a depth of 3/16 or so and you're ready to rock!
This is about the only thing in the restoration that didn't cost me MORE than I expected :D
Postby Otto Skorzeny » Mon Sep 18, 2017 12:13 pm
I went out and looked at my gas tank and straps. There is no reason to believe, or evidence to suggest that it has ever been removed from the car in its entire life.
The straps and tank on my car are unpainted.
This is a 1966 Toro, not a '70.
1970w34
Postby 1970w34 » Mon Sep 18, 2017 12:34 pm
Thanks Otto, I figured that they may not be painted but just wasn't sure. The tank I'm confident was just plain galvanized which I will try to replicate with paint. Thanks for the input!
By the way, been back to Gran Sasso lately? :D
Postby Otto Skorzeny » Mon Sep 18, 2017 5:11 pm
Haha!
No, but my brother is in Italy right now working at a medieval castle!
1970w34
Postby 1970w34 » Wed Sep 20, 2017 8:37 am
Chippin' away
1970w34
Postby 1970w34 » Wed Sep 20, 2017 8:42 am
Never will figure out the whole picture posting stuff....nothing consistent about it and that makes me nuts!
Postby Otto Skorzeny » Wed Sep 20, 2017 10:27 am
Nice. Are those KB shocks on the front?
Did you buy new drums for the rear off the shelf?
