Hi All,
I have a '67 that has hubcaps on it. I've thought since acquiring the car that it would spruce it up if it had "rally wheels". I believe that's what they're called, with the "spokes" exposed and a chrome trim ring and hub insert.
I was wondering where the heck I'd find a set of these wheels, then it occurred to me, why don't I see what's under the hubcap. See photo below.
Does anyone know, if I were to paint/plate the existing wheels, and find a set of rings and hub inserts, would I then have "rally wheels"?
I don't have any illusions that it will be easy or cheap to find the rings and center caps, but if my existing wheels will work if painted/plated, at least I'm 1/3 there instead of 0/3 there.
If anyone has an answer for this I'd be very appreciative. And as a follow up, if anyone has any insight on finding the hub inserts and rings, and how to paint/plate the wheels, that would be great too. I appreciate any help in advance.
"Rally Wheels"
rt_toro_67
- TOA Membership Number: 750
mark
- Years Owned: 3 1966 toronados,1970 buick 225 covert. 1964 olds cutlass
Re: "Rally Wheels"
rings and caps are on ebay now. use 66 caps and the rings for 67 disk brakes.mark
rt_toro_67
Re: "Rally Wheels"
Mark,
Thanks for the reply, I really appreciate it. Can you clarify a couple of things?
1. Why would you say to use '66 caps and '67 rings for disk brakes when I have a '67 with drum? Just curious.
2. I see rings listed on E-Bay but not caps. This sale: http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT is for the rings only. I've been watching for these for some time, if there's a listing I can't find, that would be great if you could point me to it.
Thanks again.
Thanks again.
Re: "Rally Wheels"
You may be interested to review my article on Generation One wheels, and a lengthy article on a 1968 Toronado drum-to-disc brake installation here:
http://www.breznick.com/toronado
Another consideration for your wheels is powder coating, which I did to one of mine (the spare tire wheel in the trunk). Not many will like the color I selected. Powder coaters have hundreds of choices. I was extremely happy with the quality of Bulls Eye Powder Coating in Miami, FL.
- NewToro - 32a.JPG (199 KiB) Viewed 16815 times
- DSC02871a.JPG (152.28 KiB) Viewed 16815 times
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
mark
Re: "Rally Wheels"
with 67 drum use 66 rings,caps were on ebay july 14,keep looking more will come on.northtown autoparts has 3 listed on car-part.com @ 35.00 each in toledo 1-800-430-6610.,mark
mark
Re: "Rally Wheels"
1 was at a shop today and they have 11 66 caps for sale
rt_toro_67
Re: "Rally Wheels"
Thanks for the tips everyone.
mikesteam
- Years Owned: 1966 olds toronado standard & 1966 olds toronado delux & 1983 olds toronado
Re: "Rally Wheels"
Hi - David B i like the powder coated wheels , not the color, your idea is good . I saw your post on ist gen wheels toronado ; i do not agree that they are ugly . the 66 toronado had styling cues from the 37 cord 810, 812. fantistic ! i wouldn't use any other style wheel.
Re: "Rally Wheels"
The spare tire wheel is actually dark blue. The flash photograph falsely lightened the color to a powder blue level. It appears much better in person.
The 4 custom wheels on my Toronado were all powder coated gloss black, and have an unbeatable look. The aluminum center caps were designed and fabricated at a local machine shop. I am extremely happy how the wheels came out, and I recommend powder coating.
- NewToro - 42a.JPG (100.46 KiB) Viewed 16567 times
- NewToro - 06a.JPG (173.63 KiB) Viewed 16567 times
Dave B.
Miami, FL
TOA # 99
Miami, FL
TOA # 99
Re: "Rally Wheels"
Wow, those are some pretty mean looking wheels... Especially with those flat tires... Doesn't look like it has any branding labels o.o never seen that before.
If you lookup pictures oF "The Terrible Toronado" you can see a '66 with actual, factual rally wheels on it. Of course, they replaced the.axles, and added a 2nd engine and transmissoon in the rear to do it
I've got an extra set of drum brake beauty rings if ypu need them. I just got new disc wheels for my future upgrade. IIRC, they were in pretty good shape. If you're interested let me know and I can take some pictures.
