Hi Guys, glad I found this site! I've always wanted a Toronado, and just purchased a '68, in relatively good condition about a month ago. The carburetor was seeping out at the gasket points, and it was running way rich, so I figured I would rebuild the carb. I took it off/apart, got new gaskets on it, and put it back on. There was a crack in the upper plate, so I can't be sure it sealed right, but it's not seeping out anyway. My issue, however, is now in barely runs. I broke one of the vacuum lines and connector when re-installing the carb, so I replaced the "T" connector and vacuum lines. Here's where I'm at...I reset the gas/air mix on the carb, checked the idle, and checked all the rest of the vacuum lines. It barely starts, and when running it's so rough it's actually shaking, and blowing big old puffs of blue smoke out the back, from too much fuel in the mix, or no air. It's acting like it's out of time, though I didn't touch the timing, so I'm wondering if the previous owner didn't compensate for the leaking carb by messing with the other settings (vacuum lines, timing, mix, etc.). I guess my questions come down to this:
1. I can't find the Rochester Quadrajet carburetors for sale new anywhere, do they still make them? If not, can you guys suggest a good alternative?
2. I have no shop manual for this car, does anybody have a vacuum diagram for the 455? I would hate to start tearing it apart looking for timing issues or something else if it's just that they "adjusted" the vacuum lines.
Anyway, I'm new here (and to the Toronado world) and I would appreciate any advice I can get here.
Thank you,
Matthew
68 Vacuum / Carb Questions
- Years Owned: 1968 Toronado
- TOA Membership Number: 173
Re: 68 Vacuum / Carb Questions
Welcome Mathew,
The man you need to talk to is Sparky he is a member here and the expert on these matters
http://www.sparkyscarbs.com/
Good luck with the carb.
Mike AKA Stubbe
TOA 173
1966 Deluxe
TOA 173
1966 Deluxe
- toro_mike
- TOA Membership Number: 4
- Contact:
Welcome Matthew! I second the Sparky recommendation. He's the best there is.
Secondly, GET a service manual!! I can't stress how critical this is. They are on eBay all the time as well as the usual auto lit sites, like autolit.com! I'll see if I have a scan of the '68 vacuum lines handy for you.
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
- toro_mike
- Contact:
I'm not finding my service manual right now and am heading for Hershey tomorrow morning. Hopefully somebody else can step up. If somebody does, I'll post them to the TOA FAQ site.
I should also advise that you pick up the Factory Toronado Assembly Manual. Lynn Davis makes them available: ildavis@networksplus.net.
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
Thanks Mike!
- TOA Membership Number: 70
