'66 Turn Signal Cable T/T Column
This category includes instruments, radio, window roll up hardware, latches, seat tracks, fabric and vinyl yardage, interior paint and dye, armrest, interior electrical switches, bulbs and lenses.
rkimmell
Postby rkimmell » Fri Feb 06, 2015 1:04 am
How does the cable attach to the turn signal up in the column? Do you have to take the C clip off to get to it? I can't find any procedure it the manuals.
Thanks!
Re: '66 Turn Signal Cable T/T Column
Postby Doc Hubler » Tue Apr 07, 2015 8:58 am
If you have a 66 manual, look under the regular Oldsmobile section on steering. THis shows tilt/telescope steering and discusses how it's attached. When I replaced mine years ago, before I had a manual, I remember I had to take everything apart to get the wiring harness out. There is a separate small cluster connection for the cornering lamps, then there is the main cluster that plugs together. I think most if not all the cars equipped with cornering lamps had TT steering wheel. IT was probalby sold as an option package. I believe there is an access cover on the side of the column you pry off to get at the cable connection.
Return to “Interior & Trim”
Users browsing this forum: No registered users and 65 guests
