It's the end of the car show season and I have been at Carlisle the last 2 days. Today I came across a gentleman who had an assortment of turn signal cams, springs and switches, his name is William Morehouse. I purchased 2 T/S cams and 2 sets of springs for my '69 and inquired about parts for the '66. I know the '66 uses the Olds 98 wheel / column assembly (only in black) and he could not find a listing in his book, it only says "See notes for 98". He told me that a guy bought a cam from him and had to modify it to work in his '66. The mod was simple requiring only a hole drilled to accept a pin to lock the cam into position to make it work, and he will supply details of this modification when you request the part. Mr. Morehouse is an older gentleman who does not use the internet but instead asked that he be faxed with your request. I told him about the TOA and said he might be getting a few responses after the word gets out; he also has parts for other brands as well. I hope this helps in our constant search to keep the Gen 1's going.
John
TOA 470
William A. Morehouse
26 Kellogg road
New Hartford, NY 13413
Phone 315-797-3515
FAX 315-797-2471
Gen 1 Turn Signals
Re: Gen 1 Turn Signals
Copied from the Technical Talk forum as those looking for these parts might be interested in pursuing this.
You can easily check out our high quality 700-505 - testking which prepares you well for1z0-899 - braindumps - questions testking. You can also get success in realciis.edu exam with the quality hodges and selftestengine.
Users browsing this forum: No registered users and 94 guests
