1966 toro trans question
- Years Owned: 66 toronado
So probably a silly question but not all that fimiliar with these transmissions. I have been chasing a trans oil leak for some time now. I am confident now that it is not coming from the transmission pan, or the vacume modulator. After inspecting again today I am leaning toward the "pan" that is on the rear of the trans, (It has a black plastic type insulated cover on it) My question is.. 1. what is in there? (is that where the chain drive is??? and 2. is there transmission fluid in there that could be leaking from that gasket between the two parts. thanks
Re: 1966 toro trans question
Is the leak trans fluid or oil? There are seals back there for both the transmission and the engine.
its transmission fluid. Im wondering if there is trans fluid in there where the drive belt/chain is?
- TOA Membership Number: 693
- Years Owned: 4 years 1966 Toronado
I had / have the same problem Please provide your phone number so we can talk at length and not duplicate the same mistakes in fixing this repair. I'm in Wisconsin, how about you?
Robert I just sent you a PM with my number. After further inspection I think I am dealing with a leaky trans torque converter front seal. I have the seal just need to find time to pull the motor. I recently rebuild the motor and reground the crank which may have moved the "track" the seal had been running on. At least thats my theory anyway.
https://www.lola.vn/u/bothbest
https://bothbest.weebly.com/
https://bambooflooring.alboompro.com/blog
https://bambooflooring.alboompro.com/home
https://zybuluo.com/bothbest/note/2625499
https://bamboochopsticks.storeinfo.jp/posts/57459969
https://connect.usama.dev/blogs/37551/Essential-Tips-for-Installing-Bamboo-Decking
https://paidforarticles.in/what-is-the-importance-of-glue-in-bamboo-decking-871186
https://bothbest.weebly.com/blog/eco-friendly-adhesives-in-bamboo-flooring
https://bothbest.weebly.com/blog/precision-milled-bamboo-flooring-why-quality-matters
https://www.123articleonline.com/articles/1491801/zero-voc-glue-in-bamboo-flooring-a-healthier-choice-for-your-home
https://bambooflooring.alboompro.com/post/321575-avoid-these-common-mistakes-when-installing-bamboo-decking
https://bambooflooring.alboompro.com/post/321256-10-essential-questions-to-ask-before-buying-bamboo-flooring
https://www.lola.vn/dien-dan/hoat-dong-cua-cong-dong/offline-cung-lolavn/choosing-safe-and-durable-bamboo-flooring.htm
https://bambooflooring.notion.site/From-Forest-to-Floor-A-Step-by-Step-Guide-to-Bamboo-Flooring-Manufacturing-27141b6b363980f6bc45ea303bea1f0d
https://www.lola.vn/dien-dan/chia-se-kinh-nghiem/dia-diem-mua-nguyen-vat-lieu-handmade/how-anti-mold-treatments-extend-the-life-of-bamboo-decking.htm
https://www.hasster.com/blogs/231271/What-Kind-of-Glue-Is-Used-in-Bamboo-Flooring
https://www.zupyak.com/p/4677600/t/bamboo-flooring-vs-hardwood-floors-cost-and-quality
https://me-page.com/p/922321/Healthy-Nature-China-Bamboo-Flooring
https://bothbest.hashnode.dev/
https://bothbest.hashnode.dev/building-a-bamboo-flooring-for-your-garden
https://differ.blog/p/zero-voc-glue-in-bamboo-floorin-a1623e
https://dev.to/bothbest/top-10-reasons-homeowners-are-switching-to-bamboo-decking-g3h
Users browsing this forum: Google [Bot] and 21 guests
