Rare Parts
- Chazzer
- TOA Membership Number: 146
Rare Parts
Does anyone out there in Toroland have any feedback to share on Rare Parts? They manufacture ball joints and tie rods for the first gens. They appear to be the only source available for these items.
Cheers, Jim
TOA# 146
TOA# 146
Re: Rare Parts
xgecko will likely chime in, as he had bought both types...
but Kanter also make sa complete front end rebuild kit. Ball joints, tie rod ends, control arm bushings, everything... much, much cheeper than the rare parts parts. I bought the kanter kit myself, (Haven't installed yet) but it's pretty nice stuff.
http://www.kanter.com///productdetail.a ... 39&Prc=182
$312 for everything you need.
- Chazzer
Re: Rare Parts
Thanks for the quick reply!
Interesting enough I restored a 67 Pontiac GP rag back in the mid 90's. I bought Kanter ball joints for it as it was all I could locate at the time. I was not very impressed with them as I recall. They seemed kinda cheesy looking and flimsy. They assured me that looks can be deceiving and they were up to the job. I'll never know cause I lucked out and found 4 Moog ones that looked much beefier and used them.
The Kanter ones are still some where in the storage room!
I heard that the Rare Parts guys were some how associated with Moog, ex employees or ex -engineers...something like that (just a rumour I heard).
Cheers, Jim
TOA# 146
TOA# 146
Re: Rare Parts
I bought the Rare Parts Ball Joint only set for about $610. I then I saw that Kanter has the full set plus tie rod ends plus suspension bushings for $312. Needless to say I returned the Rare Parts set as I was still ahead by $190 after the 20% restocking fee...
So far they seem fine. I put a few thousand miles on the car over the summer and it shows no signs of wear.
- Chazzer
Re: Rare Parts
X,
That is a big difference in price no doubt about it.
Question for you: when you returned the parts to Rare Parts did they wanted to know the reason? If they so, did they they have any comment on the big difference in price?
Cheers, Jim
TOA# 146
TOA# 146
Re: Rare Parts
They did not hassle me in the slightest. Rare Parts does seem to be a good place to do business, just make sure their pricing is acceptable. I do not recall telling them why I was returning them but it would not have mattered; they charged me 20% so had no reason to care.
- Years Owned: 1967 Toronado
Re: Rare Parts
Twilight Fenrir wrote:xgecko will likely chime in, as he had bought both types...
will this work for my 1967 toro?
Re: Rare Parts
All first gen Toros have interchangeable parts for almost everything. In the case of the bushings for sure, and I love them. The handling improvement is likely to be large, although I cannot truly tell. I just know my car handles fantastically with zero play in the front suspension. The slightest move of the steering wheel produces an appropriate output. Granted, I have a custom built Steering Box that is extremely low tolerance, so that is part of the reason for such good response, but the bushings definitely play a role.
The bushings I am referring to are Schurkey's polyurethane bushings - which I would get over the Kanter rubber ones, so that really changes things based on your post. I would consider your application: performance or luxury. Luxury might be better served by the rubber bushings which will provide a slightly softer ride at the expense of chassis response.
Assuming Schurkey is still selling them. In fact, I might want to get an extra set, so I think I will inquire.
I would not hesitate to install them. Just follow directions and be careful when removing and installing from the control arms. It is not hard if you are careful.
Re: Rare Parts
I installed the Kanter kit on my car. Really haven't yet driven it yet as I'm just finishing the restoration, but the Kanter parts really did seem just fine and like the originals. I replaced all suspension parts on the car with the exception of the rear spring to axle pads which were not readily available and were still in excellent shape on my car.
I had purchased from Rare Parts many years ago for my 41 Hudson pickup restoration. They had excellent parts. At the time, they really only sold to businesses, and individuals only for premium price, so I suspect that is still the reason for the price disparity. Their parts are excellent also, but go with Kanter for affordability.
