66 Drum to Disc Conversion
ride_there
TOA Membership Number: 400
Years Owned: 1966 Deluxe
Re: 66 Drum to Disc Conversion
Postby ride_there » Fri Nov 05, 2010 12:31 pm
.[/quote]
Whoa, thats good news to me! Better than digging up 70's toro and re-scraping it. Could you post an item #, and issue of the catalogue so I can e-mail them about it? A scan of the page would be awesome too. This is something I wanted to do to my 66.[/quote]
I will post more info when I get back home this weeked...
carl
ride_there
Postby ride_there » Sat Nov 06, 2010 5:17 pm
For those that have asked:
The catalog is free from Kanter. I have to affiliation with them, I have ordered parts in the past though.
You can request a copy at: http://www.kanter.com/catalogrequestQAS.aspx
The issue sent to me is the fall 2010 issue. The new brake conversion kits are listed on page one.
kits include:
2 - 12" rotors
2 - single piston calipers
1 - set of pads
2 - caliper mounting brackets
2 - brake hoses
wheel bearing, seals, hardware
Master cylinder
power booster
proportioning valve
I am hoping someone will post experience with this kit in the future.
TOA Membership Number: 839
Postby Twilight Fenrir » Sat Nov 06, 2010 5:52 pm
Hmm... well, that doesn't sound complete to me... it's missing the control-arm parts... unless the "Caliper mounting bracket" somehow adapts to the existing ones...
Thanks for the info, I'll let you know if I order it.. . will probably be a couple months though before I do....
Postby Twilight Fenrir » Fri Nov 19, 2010 11:46 am
Well, I just got my kanter catalogue... And i'm shocked! They say that with thier kit you can still use the factory drum wheels! I'll call and confirm this a bit later... But that makes this an optimum solution. Son't have to dig arround for wheels even, and live with the uglier (imo) disk-wheels.
mikesteam
Years Owned: 1966 olds toronado standard & 1966 olds toronado delux & 1983 olds toronado
Postby mikesteam » Thu Jul 28, 2011 4:34 pm
hi i am new but saw the kanter cat. with the disc conversion for the 66 toro. Well I CALLED kanter and they said the don't know anything about it ! just wanted to check this out.
Postby Twilight Fenrir » Thu Jul 28, 2011 6:31 pm
mikesteam wrote:hi i am new but saw the kanter cat. with the disc conversion for the 66 toro. Well I CALLED kanter and they said the don't know anything about it ! just wanted to check this out.
They made the kit through this winter, and discontinued them... They discontinued them a month after I had the money to afford one :P Oh well, I pieced together a set myself, so I'm all set to go. But, that's where the kanter kit stands for the time being.
mikesteam
Postby mikesteam » Thu Jul 28, 2011 9:57 pm
thanks for the heads up on the kanter drum to disc kit - i think this winter i will do one of my 66s drum to disc. Brake Tech Solutions will do a 66 toronado for about $1000.00 they claim they have done these cars before.
accictape
TOA Membership Number: 411
how long do you have to take cialis before sex
Postby accictape » Sun Jul 28, 2024 3:12 am
If you take cholestyramine, colestipol, or sucralfate, ask your doctor or pharmacist how to take them with Urex Forte solution <a href=http://cialis.lat/discover-the-best-prices-for-cialis>best place to buy cialis online forum</a>
