Well, it looks like our wheels are once again limiting our choices. When I assembled everything and was able to actually attempt to put the wheel on it did indeed interfere with the caliper.
I attempted to grind down the caliper and bailed when it seemed like it might be too much - however, after I removed them from the car I suspect I may yet be able to get them to work.
I do, however, have a set of rebuilt stock calipers which I decided to revert to for this summer. This allows me to baseline the performance of these while also moving forward with a minumum of hassle now that the season is upon us.
I will be upgrading the entire braking system next fall with parts from a 1978 Eldorado I bought last weekend for the rear disks and the Hydroboost hydraulic power brakes. Thus I think I will make another attempt at that point given that I already destroyed one caliper. My sense is that they can be shaved down enough to work but you will need a strong constitution to accomplish this with more than $300 worth of parts...
So my current recommendation is that this be considered unproven and not a valid solution for most folks. I can also say that simply painting the cast iron calipers results in a signficant visual upgrade when combined with the chrome wheels...
I will now take myself out back and spank myself for having made the original post without complete verification...
Update on Aluminum Calipers - will not fit unless modified
Re: Update on Aluminum Calipers - will not fit unless modifi
Yeouch, that was an expensive experiment... Guess i'm going with the regular '69 calipers
Hey, speaking of chrome wheels, you wouldn't know where I could find a set wouldya? I'm surprised how hard they are to acquire. I figured there'd be a big pile of them with all the parts cars people usually keep.... wheels are the last thong holding up my disc conversion. Just ordered my Firehawks, cuz no local shop could get them.
Yeah, I am pretty certain they can be shaved to fit, but I decided to hold off for now. I might as well try to make the one fit since it is already trashed, but now I have all summer to work on it. My current goal, as you probably can relate to, is to get behind the wheel as soon as safely and practically possible.
My chrome set came with my '69. My '68 came with grey painted wheels. My ultimate goal is to have 17" wheels custom made at some point with a modern 5 spoke look. Gotta figure out what will look good though as I have seen several pics online that looked... best I not say.
I hope to get the starter installed today then finish the right side knuckle and axle install. After that I need to get a welder as I decided to weld the new exhaust instead of using clamps. Looking at a Lincoln 180C MIG welder next week.
Once I get the exhaust I will put in the radiator with the 2 Summit Racing 16" electric fans that fit perfectly.
I hope to finish the engine bits and throw on the carb and cross my fingers sometime around the end of the month...
Sounds like a plan to me Been there. I'm on hold again personally, one of my tires decided to decintigrate and took some of my Q/P along with it. My tires looked perfectly serviceable a week ago... but they all look nightmarish now... rubber rotted, and I didn't notice till much to late :-S
The metal work should be easy, I just gotta get off my kiester and do it. no rush since I'm waiting 2 weeks for my tires to get here...
I think my welder is a Lincoln 180... I've had it for 3 years now... and it's still new in the box haven't had anywhere I could plug it in 'till now.
I've seen alot of aftermarket wheels on Toro's... mostly here:
http://www.breznick.com/toronado/wheels/index.htm
Which has technical information on our wheel-needs, if you happen to need such information when you go to get yours made. As well as just alot of general information that's really helpfull.
I have yet to see a single toronado that had aftermarket wheels that I liked the looks of over the factory. Mine are painted steel, and I really do like how they look with the centers and trim rings. But, if I gotta replace my wheels to use disc, I'm goin' chrome
Best of luck getting her going by the end of the month!
Ouch! I bought my '68 with a crushed passenger fender, valence bumper and damaged door so I am going to get a parts car and use that for new panels. However, I suspect that it is very possible to do a fine repair with a mig welder given how thick the steel on these things is.
I do know about that link, it is where I got all my info and did my own search which confirmed there is no way to get custom wheels for it. It is indeed a good source.
I am going to try to figure out if I can find something that works. If I fail I may go the Leno route and duplicate the original look in a larger rim.
Got the starter in and realized I had not marked the wires when I took it out... I put the red wire on the block side of the solenoid and the yellow wire on the outboard side. I am pretty sure that is right...
Watch for a special feature covering wheels and brake in the up coming issue of Driver Magazine. I am sure many will find it very informative.
Also John Dorcey jdoctoro@aol.com has 66-67 drum and 67-70 disc (welded) re-chromed wheels at a very competitive prices give all if the handing involved.
69W34 wrote:Watch for a special feature covering wheels and brake in the up coming issue of Driver Magazine. I am sure many will find it very informative.
Yup, I just bought a set of re-chromed disc brake wheels from him. Along with a set of beauty rings to go with them. Looking forward to getting them, and getting my toro back on the road.
Return to “Suspension, Brakes & Steering”
Users browsing this forum: No registered users and 79 guests
