?.. 66 olds chassis service manual/Fisher Body Manual
pudland
TOA Membership Number: 987
Postby pudland » Sat Sep 15, 2012 8:30 pm
I've spent a few hours paging through the "manuals" and I'm having a hard time finding anything that really matches my 66 Toro...
Ex... the Climatron control....
Did I waste a few bucks or am I just missing everything????
Is there a better service manual?
Thanks,
Adam
____________
TOA# 987
1970w34
TOA Membership Number: 38
Years Owned: 1970 multiple
Re: ?.. 66 olds chassis service manual/Fisher Body Manual
Postby 1970w34 » Sun Sep 16, 2012 9:05 am
The factory manuals will have all the service procedures and points of pertinence. If you are looking for restoration information you can't beat the assembly line manual which shows how everything goes together. Lynn Davis sells reprints of these for a very modest cost. I'm sure someone here can post his info--I'll look in my stuff and get it for you if not.
pudland
Postby pudland » Sun Sep 16, 2012 3:06 pm
Basically.....
The htr/a.c. blower wasn't working.... my cousin pulled a vacuum and a couple days later I flipped the switch and the blower kicked on... I didn't run it long on account of the oil not being able to circulate. The chassis service manual didn't show the control assembly that I have.
I don have any push buttons.. only a lever and a potentiometer.
I was looking for electrical/vacuum diagrams for my systems.
Thanks,
Adam
____________
TOA# 987
Postby Twilight Fenrir » Sun Sep 16, 2012 8:00 pm
Well... If you're working off the Chassis Service manual, that is the correct book. I've run some maintenence on my Comfortron out of this manual. All the stuff for the Toronado is in the very back of the book, after the yellow indexes. The 94 & 96 series... Anything specific to the Toronado is in these pages. The information on the Comfortron begins on page 1EB-1. As far as I can tell, all the information you should need on its troubleshooting and maintenence is located within these pages. Minus part numbers.
The control mechanism you describe sounds like the Comfortron, you should have a wheel with temperature numbers marked in it to the left of your levers, yes? IIRC, the wheel to the right is for cruise control. (though I may have those two reversed)
Just to be clear, we are talking about this manual here:
http://www.ebay.com/itm/1966-Oldsmobile ... e7&vxp=mtr
The book in the link is a reproduction... if you want an original one as I have, there are generally a few on at any given time.
pudland
Postby pudland » Mon Sep 17, 2012 4:07 am
Twilight,
I got the chassis service manual from Faxon literature... it's in pdf form on a CD.
The total page count of the file was 1250 pages or so(I will verify that when I get home from work.)
I will look for and scrounge through the sections your pointing to.
Thanks for clarifying this for me!
Also... the physical layout of the comfortron is how you described it. There is a "dummy" wheel to the right and a wheel with temp graduations on the left.
Thanks,
Adam
____________
TOA# 987
Eightballz
TOA Membership Number: 826
Postby Eightballz » Mon Sep 17, 2012 5:57 am
you'll find all you need on www.wildaboutcars.com ..FOR FREE!!
pudland
Postby pudland » Mon Sep 17, 2012 8:45 am
Thanks for the link! Is the Toro an "a, b, or c" body?
Thanks
Adam
____________
TOA# 987
pudland
Postby pudland » Mon Sep 17, 2012 9:23 am
Sooo... I got on wildaboutcars and saw that there is the Toronado Supplement.....
Which I'm pretty sure didnt come with the one I bought!!!
Ahh well!
Serves me right for not asking the forum BEFORE I spent the $30... Eh, I'll survive!
Adam
____________
TOA# 987
Postby Twilight Fenrir » Mon Sep 17, 2012 10:42 am
Toronado is an E body
waleeedijaz
TOA Membership Number: 1
Postby waleeedijaz » Sat Mar 12, 2016 3:07 am
