Master Power Window Control Unit
monnogram
Years Owned: 2
Postby monnogram » Mon Jun 28, 2021 1:31 pm
I am able to raise and lower drivers side window and lower the passenger window. I cannot raise the passenger window or or lower the rear windows from the master control. These windows can be operated with their individual control levers. To check the master control switch/wiring, do I have to remove the inside door panel or is the unit accessable from the outside. 1968 Toronado.
Re: Master Power Window Control Unit
Postby Otto Skorzeny » Mon Jun 28, 2021 4:26 pm
I'd be willing to bet that the conections on the master control just need to be cleaned /wire brushed/emery cloth/etc.
monnogram
Years Owned: 2
Postby monnogram » Mon Jun 28, 2021 8:40 pm
My thoughts as well. Can I remove the control unit from inside or do I have to remove the door panel to inspect it?
Postby Otto Skorzeny » Tue Jun 29, 2021 5:05 am
My car has roll up windows so I don't know.
Tuco
Postby Tuco » Tue Jun 29, 2021 5:21 am
Not sure about the 68 but the master switch in the 66 can be removed without removing the door panel.
monnogram
Years Owned: 2
Postby monnogram » Tue Jun 29, 2021 5:54 am
Thanks, I'll try it.
Users browsing this forum: No registered users and 89 guests
