Page 1 of 2
Gas Mileage
Posted: Fri Jul 10, 2009 1:49 am
by Dracofrost
On a 1966 Toronado in good condition, what is the gas mileage expected to be? What is normal, or what was normal for them new or in fully restored condition?
Re: Gas Mileage
Posted: Fri Jul 10, 2009 5:43 am
by 69W34
One could expect 14-18 city / highway give any number of factors, motor condition weather and driver technique. The 66-67 came with 3.21 gears considering its 4400 hundred pound weight and 425 cubic inch displacement, and 32 cent a gallon gasoline that was exceptionable.
IMHO Driver technique plays a bigger roll in fuel usage than some are willing to except. Case in point my wife gets 18+ around town with our 02 Caravan I get 20+
Re: Gas Mileage
Posted: Thu Jul 23, 2009 4:59 pm
by toro68
My gold '68 W-34 does 17 on the highway, that is 3.07 gears
Re: Gas Mileage
Posted: Fri Jul 24, 2009 3:29 pm
by Dracofrost
Alright, if I'm only getting 7 mpg city (and I don't drive like a maniac, I have to obey base speed limit which is 30 mph most of the time), is this a sign of mechanical problems? Any likely problem areas to start looking in?
Re: Gas Mileage
Posted: Sun Jul 26, 2009 10:28 am
by MattKing
Check the intake manifold vacuum level at idle. Any vacuum leaks will kill gas mileage and drivability.
Dracofrost wrote:Alright, if I'm only getting 7 mpg city (and I don't drive like a maniac, I have to obey base speed limit which is 30 mph most of the time), is this a sign of mechanical problems? Any likely problem areas to start looking in?
Re: Gas Mileage
Posted: Sun Jul 26, 2009 2:43 pm
by janeg
We average 12-14 mpg on our '66, using premium gas and lead additive. Most of our driving is not city, but 40-50mph country highways. Still 7 mpg sounds low to me. Has your carb been tuned?
Re: Gas Mileage
Posted: Sun Jul 26, 2009 2:51 pm
by Dracofrost
Not a bit. I only purchased the vehicle a couple months ago, prior to which it had been sitting in a garage for about 10 years. How do you check vacuum levels?
Re: Gas Mileage
Posted: Sun Jul 26, 2009 10:07 pm
by MattKing
Get a vacuum gauge and connect it to the biggest connection you can that has manifold vacuum-the line that supplies the brake booster is a good one.
Dracofrost wrote:Not a bit. I only purchased the vehicle a couple months ago, prior to which it had been sitting in a garage for about 10 years. How do you check vacuum levels?
Re: Gas Mileage
Posted: Fri Aug 07, 2009 11:12 am
by nickh
If the car has been sitting up for that long the Carb needs to be rebuilt probably a lot of sludge build up inside the carb. If you do not want the carb rebuilt another option is an Edelbrock 4 bbl carb it is a direct replacement for what you have. A complete tuneup including points and new plug wires will also help.
Re: Gas Mileage
Posted: Tue Aug 11, 2009 9:10 am
by Mikel
I typically get about 13 in my '66. The very best I ever got was 15MPG during a very slow drive through northern CT, MA and down the Taconic Pkwy into NYC.
