I’m sure this has been discussed on here before but I’m not finding much in the searches.
Has anyone gone to a dual master cylinder on a 66? I’m not talking about a disc conversion, just the mc swap.
I’m wondering if there is a noticeable difference. I understand the safety aspect but I want to know if there is any improvement of stopping power.
I just replaced the booster and master on my 66 and the brakes are just ok. I plan to bleed them again but don’t expect much improvement. Is it worth the time and expense to upgrade?
Thanks.
66 Brakes?
Re: 66 Brakes?
Hi Tuco. The only difference will be safety (you'll only lose brakes on two wheels instead of four if you have a leaking wheel cylinder) and peace of mind. Stopping power and stopping distance aren't affected by a dual master cylinder.
Safety is the only reason dual master cylinders were adopted/mandated.
Re: 66 Brakes?
Thanks Otto. I kinda figured that would be the case. Just wishful thinking.
Do you still have the single res on yours?
Re: 66 Brakes?
Not yet. When and if I have to replace the master cylinder, I'll consider making the switch then.
I'm not too worried about the single reservoir though. People like us who drive old cars pay a lot closer attention to everything under the hood, puddles in the driveway, etc. than your average driver. I think if trouble is brewing we'd notice it and fix it before it became dangerous.
My mom has been driving a 1964 Galaxie 500 since 1989 and it has a reservoir nearly identical to the Toro. She's never had a problem. My '56 Cadillac has a single reservoir and has been my primary vehicle for 19 years. I've never had trouble with it, either. I check the fluid all the time and pay close attention to any difference in braking.
I'm pretty confident that a sudden failure is unlikely.
Users browsing this forum: Google [Bot] and 33 guests
