'66 Toro. I got a U-Jamb sealing kit from Steele that includes Lock pillar fillers and Auxiliary seals. My restoration guy couldn't figure out where/how they went, and I can't see it and don't have any pics to reference.
Could someone that has the lock pillar seals correctly installed please post or email me some pics? 1966-70 should all be the same. I've attached a pic of the parts from the Steele catalog.
Thanks!!
wyobuysell@gmail.com
lock pillar seals
- TOA Membership Number: 1373
- Years Owned: 1966
lock pillar seals
- IMG_0755.jpg (1.9 MiB) Viewed 12985 times
Re: lock pillar seals
I'll take some pics for you tomorrow.
I'm not entirely convinced that those pieces offered by Steele are correct.
Here is my car. As far as I know, these are the original parts. They don't look exactly the same to me. The Auxilliary ones have only one screw holding it in place, not two.
- IMG_20200406_133958.jpg (204.37 KiB) Viewed 12981 times
- IMG_20200406_133935.jpg (190.2 KiB) Viewed 12981 times
- IMG_20200406_133930.jpg (218.8 KiB) Viewed 12981 times
- IMG_20200406_133927.jpg (203.4 KiB) Viewed 12981 times
- Years Owned: 1966
Thanks Otto, this is VERY helpful. My jamb does have two holes for the auxiliary seal and that seems to make a good fit/seal. The U-jamb seal holes, however, don't line up. Hopefully once I finally get through all the boxes my Dad packed away I will find the old seals and can determine exactly what is what.
That's weird. Would you post a picture of yours?
My car is a VERY early '66. Maybe they changed the seal later on? My car has the early Q-Jet without mechanical linkage for the secondary air horn. It uses atmospheric pressure differential to open at high speed.
It also has a longitudinal crease in the center of the trunk lid which GM thought would stiffen the lid (it didn't, and probably less than 500 were made this way, I'm told)
- Years Owned: 1966
File size issues with this forum (really?, memory limited?). If you'll provide email I will email them to you.
- Years Owned: 1966
Otto; How is that jamb seal, the lower one that is notched and slit, attached? I'm working with Steele to be sure the part I received is correct, and exactly where it mounts. I only have one hole lining up, which doesn't seem right. If you can take a couple close-ups that would be great.
Thanks for being a great resource!
- Years Owned: 1966
Joy of joys, I found the old ones and the mysteries are (mostly) melting away. My Dad had a (former) son-in-law helping with his disassembly, so there is some confusion in how things are ordered, but anyhow I found 'em!
This is quite a joint, some 4 weatherstrips getting slammed into a door shut!
So you figured it out or do you still need pictures? Are the Steele products correct?
Users browsing this forum: No registered users and 58 guests
