Hello
Everyone I had my gas tank re condition inner and outer all the line were replaced
I had to use the original sending unit
The other day I might have over filled my gas tank
And parked it on a hill pointing up forwards
When I came back to the car there was a trail 8 feel long of gas on the ash fault
Looked like it was coming from the passenger side rear almost on top of the right exhaust tip
Anyone have any idea
Gas tank leak
- TOA Membership Number: 24
- Years Owned: 1966 toronado
1981 toronado
1990 toronado
1991 toronado
1992 toronado
Re: Gas tank leak
The passenger side of the tank at the top is where the fuel line and vapor recovery line (ac models only) enters the tank. The vent pipe is also in this area at the top right front of the tank.
Do you have a factory service manual? There is a diagram of these connections in it.
My guess is over-filed and possibly fuel hose connection at tank might be leaking/loose. Pointing forward on a hill would put all the fuel in that particular area so any old gaskets, loose connections, etc would be submerged.
Overfilling combined with hot sunny day may also expand the fuel causing it to rise into the vent pipe and onto the ground.
1981 toronado
1990 toronado
1991 toronado
1992 toronado
Re: Gas tank leak
Thank you otto
I’ll have dig futher into this it has never happened
And I did the tank and lines back in March
Maybe I just really over filled then park on a hill in a wAy like you said would make it over flow
Users browsing this forum: Bing [Bot] and 50 guests
