67 power steering pressure hose
Slang3400
TOA Membership Number: 1221
Postby Slang3400 » Fri Jun 23, 2017 6:58 am
hello- I'm having trouble finding the subject hose with the correct hardline fittings. anybody found a good source? thanks
Re: 67 power steering pressure hose
Postby Otto Skorzeny » Sat Jun 24, 2017 6:32 am
I bought a new one from Rock Auto for my '66. It had the correct fittings but was not the identical shape of the original although it connected just fine without interference.
A good option is to take your old hose to a place that works on forklifts, heavy equipment, and/or semi trucks. They'll have the equipment to make hydraulic lines of any size, shape and length with the correct crimped fittings.
Postby Doc Hubler » Fri Jun 30, 2017 9:49 pm
Take your original to a hydraulic shop and have them clean/re-use the metal connector parts and replace the hose to correct specification. I did that for mine. It's impossible to find the correct hose for these. And 67 up Eldorados are different.
Slang3400
Postby Slang3400 » Thu Jul 06, 2017 6:44 am
Thanks everybody. My local shop said they couldn't reuse my orig fittings so I bought a new hose from Advance pn 36121. The fitting angles are a little different but close. I think it looks better than their recommended hose pn 36212.
Users browsing this forum: No registered users and 50 guests
