My thinking is rather than go through all the effort of a disk conversion for my 66 Toro I would feel safer by just replacing the single reservoir master with a dual master -- and keep the drums all around.
My question is: Can I get a 67-69 dual master, add a proportioning value and be done with it?
Any advice or parts recommendations would be appreciated. Btw I had a failure of a single master cylinder on my 66 GT350 and it was one of the most vivid events in my life -- don't wish to repeat it. Thanks guys.
Thad
Dual Master for 66 Toro
Re: Dual Master for 66 Toro
Yes, that is a lot more sensible than a disc brake conversion. There is a thread on this forum discussing it if you can find it with the search function. I don't think the system uses a proportioning valve for 4 drums but I don't remember for sure. You will need to get the booster for the dual reservoir system.
I have a 66 with it's stock configuration. If I ever need to replace the mc, I will likely convert. In the meantime I am diligent at making sure the brake system is in perfect order before driving it.
Users browsing this forum: No registered users and 44 guests
