Loss of power
Slick66
Loss of power
Postby Slick66 » Thu Jun 06, 2024 5:04 pm
Been driving my 66 for 2 months. Has new plugs. Has rough idle. It is definitely underpowered mostly but ONLY when I punch the gas quickly the car does take off. I imagine a cylinder isn't firing properly, not sure. Fixed two vaccum leaks. It used to ping under load in the beginning. Hasn't for about a month and a half. I gather I burnt a decent amount of carbon out. Two days ago while the car was under load uphill, I punched the gas and I heard what sounded like a very loud pinging accompanied by a slight screech. Made it home no problem. Drove the car even under load for two more days, no problem just low power. Occasionally oil spits out of the filler tube.Does anyone have some ideas of whats going on?
Re: Loss of power
Postby bcroe » Sun Jul 07, 2024 7:01 pm
Start by making sure the timing chain set has been changed out.
Check vacuum and weight advance in the distributor are working
properly. Bruce Roe
Slick66
Re: Loss of power
Postby Slick66 » Tue Jul 09, 2024 11:46 am
Thank you sir, will do.
Users browsing this forum: No registered users and 21 guests
