Thanks haha it’s a good thing RockAuto had the rag joint in stock. I also got the KYBs there too and am not disappointed with them.
The driver side CV boot has a rip and leaked grease everywhere. If it’s bad what would happen to the car?
1st Generation Toronado Steering Box
Re: 1st Generation Toronado Steering Box
All the grease leaks out and the ball bearings wear out. Water and dirt get in thewre and wear out the ball bearings, etc. etc. Then you have to replace or rebuild the entire CV half shaft.
Since I'm lazy, I opted for the Dorman Speedi-Boot, which is a clamshell style boot. The sides overlap for a good seal and its stitched up with tiny screws and 1/4" nuts.
It comes with a large packet of CV grease. It's tedious but relatively easy.
Start with the big end and work your way out. The seem overlaps and is stitched up with tiny screws and nuts. Do the outer fold skip the next inner fold and do the next outer fold. Go back and do the inner one and then move on to the next outer, etc.
When the outers are closed, it naturally pulls the inner one together so its easier to get the screw in.
Punch the screrw through both halves first before starting or you'll never be able to do it. Position the screws ahead of time as shown.
Don't fasten the inner and outer bands until its all done. Position the seem in a straight line with the wheels straight ahed when tightening the bands. The wheels can be turned to full lock whiole assembling the boot for easier access.
Pack the grease into the joint with a one inch wide putty knife for a nice flat , clean look (see pic #3). You don't want that grease all over the inside of the boot.
I'll find the part number for you. Check to make sure the cv joints are the same as the ones for 66 in terms of outer diameter.
- IMG_20210313_124006.jpg (307.24 KiB) Viewed 13219 times
- IMG_20210313_122411.jpg (232.4 KiB) Viewed 13219 times
- IMG_20210312_183252.jpg (285.19 KiB) Viewed 13219 times
Dorman Speedi-Boot #03609
It might be a bit late, but I had my Box rebuilt by Redhead here in Seattle and it is fantastic. So tight the slightest turn results in a change in direction, exactly as I requested. I wanted as close to a Rack and Pinion as possible, and they sure did deliver.
https://redheadsteeringgears.com/
How much was the rebuild for yours?
I recall it being in the $300 or so range, which I felt well worth it given how tight and smooth it is.
Users browsing this forum: Majestic-12 [Bot] and 4 guests
