Headlamp Check Valve
bstone63
Years Owned: 66 Toronado
Postby bstone63 » Sat Nov 25, 2017 12:45 pm
I'm pretty sure I found out why my headlamps won't open. Instead of the check valve that is connected to the vac source, vac tank, and headlamp switch, there is just a regular tee fitting. Does anyone know of a replacement part? I can't find the GM 394420 anywhere.
bstone63
Re: Headlamp Check Valve
Postby bstone63 » Tue Nov 28, 2017 4:02 pm
Fixed!! 8-)
Bought a $5 check valve from a local parts store and they started to open. A couple of snips on the ends of a couple other vacuum lines and voila! Plus I now have heat as well.
Postby Otto Skorzeny » Thu Nov 30, 2017 1:52 pm
Good deal!
Can you post a picture of the repair? Where was the valve? What year toro?
