I know that this is an Old Post... No need to taunt... I just feel that the information should be shared.
The ELC in both of my 1985 Toronados had failed Ride Height Level Sensors. This failure causes the vehicle to squat down in the back and ride with the prow elevated... Unsightly, uncomfortable & squirrely. I have read that these Ride Height Level Sensors are hard to replace (as in: unobtainium). Many folks did away with the system all together or just installed Air Shocks. Many others just did away with the vehicles.
I have cobbled together fungible substitutes and am quite pleased with the result. With these I just rebuilt & modified both of the systems on my 1985's and they are functioning perfectly.
Additionally, I placed the Compressor on an Ignition Switched Relay and left the Exhaust Solenoid Hot... no more dead batteries from slow leaks.
79-85 E-body ELC (Level control)
sosuzguy
- Years Owned: Jayson Pruitt ROA#3412
Riviera Owners Association
Technical Advisor 79-85
Oil & Gas Minerals/Royalties www.royaltyminerals.com
www.cardomain.com/id/sosuzguy
1983 Riviera "Cole"
1983 Riviera XX "Peter" 1 of 502
1984 Riviera T-Type "Tina"
1985 Riviera "Gray" - Location: Dallas, TX
- Contact:
Re: 79-85 E-body ELC (Level control)
What were your " fungible substitutes" ?
Riviera Owners Association - Technical Advisor 79-85
Toronado Nut too!
Toronado Nut too!
cwripinz
- TOA Membership Number: 1307
- Years Owned: Own Two Matching 1985 Gen 3 Broughams...
Will own a 1969, eventually. - Location: The Peoples Republic of Denver, Colorado
Used GM 22189430 from wrecking yard... Took vehicle side of the connector, too. Spliced cannibalized connector to vehicle. Bolted up Level Sensor. VOILA! Pure Freakin' Magic!
NOTE: One of my 1985 Toronados was wired up BACKWARDS! Had to swap Exhaust Solenoid and Compressor Signal Leads in the connector... Defective from the factory? Looks like it was!!
cwripinz
CORRECTION: I used GM Part Number 22153656!!! Sorry... Reading from the wrong set of notes!!!
ADDITIONAL: I also took the Arms off of my Old Sensors and installed them on the Replacement Sensors... Slight difference in Arm Length... Didn't want to mess with potential geometrical irregularities.
cwripinz
cwripinz wrote:ADDITIONAL: I also took the Arms off of my Old Sensors and installed them on the Replacement Sensors... Slight difference in Arm Length... Didn't want to mess with potential geometrical irregularities.
This can be simply done by swapping the plate with the Arm from one plate to the other. Also, this negates your having to disconnect the Link and potentially damaging it.
sosuzguy
1983 Riviera "Cole"
- Contact:
Very nice repair and creative!
Toronado Nut too!
Toronado Nut too!
sosuzguy
1983 Riviera "Cole"
- Contact:
cwripinz, message me. I'd like to send you a message. Thanks
Toronado Nut too!
Toronado Nut too!
cwripinz
sosuzguy wrote:cwripinz, message me. I'd like to send you a message. Thanks
I am not authorized to send messages... Left contact info on voicemail at contact number for www.royaltyminerals.com
sosuzguy
1983 Riviera "Cole"
- Contact:
Ah, sorry I was out with family. Was just going to invite you to discuss your 80's Toronados w us on FB if you are on there. We have group for 79-85 E Bodies. https://www.facebook.com/groups/1979.1985.Ebody/
Toronado Nut too!
Toronado Nut too!
cwripinz
sosuzguy wrote:Ah, sorry I was out with family. Was just going to invite you to discuss your 80's Toronados w us on FB if you are on there. We have group for 79-85 E Bodies. https://www.facebook.com/groups/1979.1985.Ebody/
Sorry... Small Digital Footprint... I don't Facebook.
